Zigate dimlevel group incorrect in beta
ronaldbro
- Domoticz version: 2020.2
Re: Zigate dimlevel group incorrect in beta
Eventually switched back to beta (I figures if you needed to add a line in the deviceDB it will be in beta anyway)
So I tested the dim level and it's still exactly the same. I send lvl 30 to the group and zigate reports 46 back
ronaldbro
@pipiche, your second update of today seems to do the trick. Dim level reported back is correct now.
But I do get a constant error after setting new dim lvl:
2019-11-10 20:45:15.483 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 0:30
2019-11-10 20:45:15.320 Status: setcolbrightnessvalue: ID: fe, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 177}'
2019-11-10 20:45:15.323 Status: setcolbrightnessvalue: ID: 1a6, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 177}'
2019-11-10 20:45:15.438 Error: (Zigate) 'onCommand' failed 'TypeError':'%x format: an integer is required, not str'.
2019-11-10 20:45:15.438 Error: (Zigate) ----> Line 829 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onCommand
2019-11-10 20:45:15.438 Error: (Zigate) ----> Line 514 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onCommand
2019-11-10 20:45:15.438 Error: (Zigate) ----> Line 1108 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/GroupMgt.py', function processCommand
Yep, I’ll fix that one later
ronaldbro
@pipiche, can you please look at my message a few posts back. I’m having a lot of trouble at the moment.
Group problem should be fixed .
For your trouble, please provide context and logs to see what is happening.
I also understood that you are switch back and fourth between stable <-> beta, please do consider that I do not really plan to have backward compatibility
ronaldbro
Thanks, but I already found the problem. I had too many devices on the zigate. I moved my hue bulbs back to the hue bridge and a few xiaomi sensors to the Xiaomi bridge and then I could reconnect the Tradfri bulbs.
Probably some devices who were connected to a router before decided they liked the zigate better
Hope the number of devices on the zigate will increase next firmware. Now I have multiple zigbee networks again where the main reason for buying the zigate was to have one big zigbee network.
I don’t expect an increase of devices with firmware. You will need more memory on the zigate to do that .
But still I do not recommend moving from beta to stable, as the data structure on beta has been updated since few weeks..
ronaldbro
OK, good to know. I will stick to beta until next stable release.
[Solved] Zigate dimlevel group incorrect in beta
Thanks for your support in this matter
