Sure most have seen this
https://youtu.be/e9fpqN40uJc
In theory the Z5 stick can be unplugged and include a solid mounted device into the system. But this method work only 50/50 with Domoticz stable. After that you got the single devices with the new number, but not the hardware device in the stick list. So the new included device is invisible, even in the oczw panel and cannot be configured.
What is the way to to include solid mounted device if the stick method fail?
A solid mounted device is for example a rgbw controller that is mounted in a box with a power supply. You cannot move this to the raspi and you cannot carry the raspi connected to a car battery to the device.
Solderbro
Aeotec Z5 Stick pure include
- Solderbro
- Domoticz version: 2020.1
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
- Domoticz version: 4.10717
Re: Aeotec Z5 Stick pure include
Setup your Domoticz to be accessible via WiFi. Set it up near the new device and include it via the hardware option within domoticz.Solderbro wrote:Sure most have seen this
Solderbro
