error install on linux mint
hjlopes72
Post by hjlopes72 »
I installed linux and I tryied to install domoticz
I got this
$ curl -sSL install.domoticz.com | sudo bash
::: You are root.
grep: /etc/upstream-release: Is a directory
bash: line 100: test: /etc/os-release:19.2: integer expression expected
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 8080
HTTPS Port: 443
::: Destination folder=/home/pi/domoticz
--2019-11-07 12:57:47-- http://www.domoticz.com/download.php?channel=release&ty pe=release&system=linux&machine=i686
Resolving www.domoticz.com (www.domoticz.com)... 104.31.78.142, 104.31.79.142, 2 606:4700:30::681f:4e8e, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.31.78.142|:80... connected .
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?c ... elease&sys tem=linux&machine=i686 [following]
--2019-11-07 12:57:47-- https://www.domoticz.com/download.php?channel=release&t ype=release&system=linux&machine=i686
Connecting to www.domoticz.com (www.domoticz.com)|104.31.78.142|:443... connecte d.
HTTP request sent, awaiting response... 302 Found
Location: https://releases.domoticz.com/releases/ ... x_i686.tgz [following]
--2019-11-07 12:57:48-- https://releases.domoticz.com/releases/release/domoticz _linux_i686.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 146.185.159.228, 2a03 :b0c0:0:1010::480:1001
Connecting to releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443 ... connected.
HTTP request sent, awaiting response... 404 Not Found
2019-11-07 12:57:48 ERROR 404: Not Found.
How can I solve this ??
RogerSch
Re: error install on linux mint
Post by RogerSch »
I have the same problem... :(
MartenW
Domoticz version: 3.4834
Post by MartenW »
Sad to see that nobody has a solution, because I have the same problem. I use a i386 system with Mint
sancla
Post by sancla »
You could try try to upgrade to the latest beta if that is an option for you...
Check these howto's: https://sancla.com
MartenW
Post by MartenW »
No idea how to perform that. I use the string:
sudo curl -L install.domoticz.com | bash
On the other hand, I found a reaction from a French Domoticz user who had the same problem and a solution. Unfortunately in French.
The translation gave this text:
Actually I just found I was under a 32-bit PC and installing a domoticz info 'i686' was recovered somewhere and integrated in a query that did not lead. Going through a 64-bit PC Info in question becomes 'x86_64' and the query that references carried well and the installation completes successfully. Hoping that it will serve (I saw some topics that reference this difficulty).
It seems that the problem rises by using a 32 bits pc (not the case in my situation, intel atom n455) and installing a 64 bits Domoticz. But I’m not sure.
