Hello everyone,,
I have my product (poliprekidac.com) which sends MQTT temperature and relay control messages.
It has a standard i have to follow and cant change it to Domoticz json.reverse image search email checker port checker
I have been searching for days around forums and cant seem to get around how to show my sensor in Domoticz.
I have setup MQTT server, and it works fine, dummy sensor with simulated messages works fine.
But my MQTT messages go on a different channel and in different format.
topic: poliswitch19117/temperature
message is just float number ex: 25.00
I've tried working with events, but cant figure how to get it to the sensor.
Any help would be great.
Regards!
Tying my MQTT messages with Domoticz
Dembe
- FireWizard
Re: Tying my MQTT messages with Domoticz
As you have already a MQTT server running, I recommend to install Node Red on that machine as well. This is the easiest tool to convert your MQTT message to a MQTT message that is suitable for Domoticz.
A brief description is given here: https://www.domoticz.com/forum/viewtopi ... tt#p227219.
It is for another application, but it describes howto install:
- Mosquitto broker.
- NodeJS
- Node Red
- Tool Mosquitto client.
If you have done this, please post your results here. Afterwards we can give you a flow description.
- Mosquitto broker.
- NodeJS
- Node Red
