Visonic motion detector 433
yan1950
Post by yan1950 »
Hello
I m newbee with domoticz and I m french,nobody is perfect , excuse my bad english...
I have an old visonic alarm 433 whixh is out off work to day, but the 7 motion detectors( 433,92 ) are still working.
I would like to use it directly with domoticz with my RFlink.
I dont know how to include this type of motion sensor in domoticz( unfortunatly not only this type of sensor but all the motion sensors ! )
I have seen that theses devices( visonic motion sensor 433 ) are accepted by rflink.
Yannick
Geitje
Re: Visonic motion detector 433
Post by Geitje »
If your RFlink is succesfull added in the hardware section of Domoticz: On the switches tab in Domoticz, click "manual ligt/switch", then trigger a motion alert on the Visonic by moving in front of it, it should be automatically added.
Remember 433.92Mhz is something different than 433Mhz. The 433 RFlink does not support 433.92 devices (or only to a little extend).
Zwave, Zigate, RFlink etc.
yan1950
Post by yan1950 »
Hi Geitje
I have done that you suggest few days ago but Domoticz did not see anything when I try to add switch .
I think RFlink does not recognize visonic 433 motion detectors
I have some remotes that works perfectly with my rflink and domoticz
Theses motion detectors are 433;92, I have a RTL SDR and I can see the signal of these motion detectors but my Rflink dont care..
My motion sensors are MCPIR-3000, frequency 433,92MHz:
http://www.visonic.com/Data/Uploads/MCP ... E36306.pdf
Anyway thancks for your answer.
Yannick
Geitje
Post by Geitje »
Just check out wether your RFlink is 433,92Mhz or plain 433Mhz. I think it is 433 Mhz. In the "supported devices list" you find it supports Visonic 433Mhz sensors, but not 433.92Mhz.
Anyhow, 433Mhz motion sensors are really cheap available at Ali. See for example: http://www.aliexpress.com/item/4000047693601.html?
Remember range is not very long, and if you use it for security alarms: 433 can easily be jammed.
yan1950
Post by yan1950 »
I do non want to use these motion detectors for alarm in my house, its only as swicthes for lights.
I have an alarm Visonic Powermax not installed for the moment and with 868 MHz detectors( motion and doors switches )
I use to buy electronis modules and components in Ali's shops in China( more than 250 purchases ); I think I m going to buy detectors as you suggest They are very cheap. It was only to do not put these 7 motion detectors in the waste basket !
Yannick
