Howto compare the current energy consumption with the consumption yesterday at the same time  [Solved]
steef27
Post by steef27 »
I am looking for a possibility to compare the current energy consumption with the consumption yesterday at the same time.
I want to be able to determine whether the cumulated consumption is higher or lower than yesterday at the same time.
For now I have found scripts that calculate averages over 24 hours, but that is not what I am looking for.
Does anyone have an idea? Thanks in advance!
Re: Howto compare the current energy consumption with the consumption yesterday at the same time
steef27 wrote: Saturday 02 November 2019 12:18 I am looking for a possibility to compare the current energy consumption with the consumption yesterday at the same time.
You could try withthe script below. It use the persistent historical data features of dzVents.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
    this dzVents script collects the current energy return / usage to enable compararisment with yestedays figures
return
    on =  { timer = { 'every 5 minutes ' }},
    logging = { level = domoticz.LOG_DEBUG },
    data = { power = { history = true, maxHours = 25, maxItems = 1000 }},
    execute = function(dz, item)
        _G.logMarker =  _G.moduleLabel
        local smartMeter = dz.devices('Power') -- change to name of your smartMeter
        local counterDeliveredToday = smartMeter.counterDeliveredToday
        local counterToday = smartMeter.counterToday
        dz.log('counterDeliveredToday: ' .. counterDeliveredToday .. ': kwh',dz.LOG_DEBUG)
        dz.log('counterToday: ' .. counterToday,dz.LOG_DEBUG)
        dz.data.power.add -- Store current values in persistent historical data
                ['delivered'] = counterDeliveredToday,
                ['used'] = counterToday
        local power, index = dz.data.power.getAtTime('24:00:00')
        if not(power) then
            dz.log('Not enough data collected yet. Taking oldest data to compare with',dz.LOG_FORCE)
            power, index = dz.data.power.getOldest()
        dz.log('delivery dailytotal at ' .. power.time.rawDateTime  .. ': ' ..
                power.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_DEBUG)
        dz.log('usage dailytotal at ' .. power.time.rawDateTime  .. ': ' ..
                power.data.used ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.used - counterToday ),4) .. ' kwh)',dz.LOG_FORCE)
steef27
Post by steef27 »
I get an error:
2019-11-04 09:40:02.179 Status: dzVents: !Info: Not enough data collected yet. Taking oldest data to compare with
2019-11-04 09:40:02.180 Status: dzVents: Error (2.4.19): An error occured when calling event handler Log
2019-11-04 09:40:02.180 Status: dzVents: Error (2.4.19): /home/pi/domoticz/scripts/dzVents/generated_scripts/Log.lua:38: attempt to concatenate field 'rawDateTime' (a nil value)
steef27 wrote: Monday 04 November 2019 9:51 I get an error:
That is because rawDateTime is not available yet in 2.4.19. So use below script in which I used a combination of rawDate and rawTime or update to a recent Beta.
    this dzVents script collects the current energy return / usage to enable comparing with yesterdays figures
return
    on =  { timer = { 'every 5 minutes' }},
        if not(power) then
        dz.log('delivery dailytotal at ' .. power.time.rawDate .. ' ' power.time.rawTime  .. ': ' ..
                power.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( power.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_FORCE)
        dz.log('usage dailytotal at ' .. power.time.rawDate .. ' ' power.time.rawTime  .. ': ' ..
steef27
Post by steef27 »
Thanks! Works great.
Can I also add my Gasmeter in this script? Or do I need to create another script?
Re: Howto compare the current energy consumption with the consumption yesterday at the same time  [Solved]
steef27 wrote: Monday 04 November 2019 17:04 Thanks! Works great.
Yes, not a problem but best to save this script with another name or remove datafile of current script.
Datafile to be found at <domoticz dir>/scripts/dzVents/data/__data_<scriptName>.lua
    this dzVents script collects the current energy return / usage and gas usage to enable comparing with yesterdays figures
return
    data = { energy = { history = true, maxHours = 25, maxItems = 1000 }},
		local gas = dz.devices('Gas') -- change to name of your gasMeter
		local gasToday = gas.counterToday
        dz.log('Gas usage today: ' .. gasToday,dz.LOG_DEBUG)
        dz.data.energy.add -- Store current values in persistent historical data
                ['used'] = counterToday,
                ['gas'] = gasToday,
        local energy, index = dz.data.energy.getAtTime('24:00:00')
        if not(energy) then
            energy, index = dz.data.energy.getOldest()
        dz.log('delivery dailytotal at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime  .. ': ' ..
                energy.data.delivered ..': kwh . ==> Delta (' .. dz.utils.round(( energy.data.delivered - counterDeliveredToday ),4) .. ' kwh)',dz.LOG_FORCE)
        dz.log('usage dailytotal at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime  .. ': ' ..
                energy.data.used ..': kwh . ==> Delta (' .. dz.utils.round(( energy.data.used - counterToday ),4) .. ' kwh)',dz.LOG_FORCE)
        dz.log('daily gas-usage at ' .. energy.time.rawDate .. ' ' .. energy.time.rawTime  .. ': ' ..
                energy.data.gas ..': m3 . ==> Delta (' .. dz.utils.round(( energy.data.gas - gasToday ),4) .. ' m3)',dz.LOG_FORCE)
