No I meant upgrading domoticz. dzVents is completely integrated so if you upgrade domoticz, dzVents will be upgraded with it.
If you don't want that you could try to replace your rgbw device-adapter with the one below. But before you do that please make sure you made a copy from the current one
then replace the current rgbw_device.lua with the one below. No need to restart domoticz / dzVents. It will work directly (or not and then you will have to restore the kept one)
local TimedCommand = require('TimedCommand')
baseType = 'device',
name = 'RGB(W) device adapter',
matches = function (device, adapterManager)
local res = device.deviceType == 'Color Switch'
adapterManager.addDummyMethod(device, 'setKelvin')
adapterManager.addDummyMethod(device, 'setWhiteMode')
adapterManager.addDummyMethod(device, 'increaseBrightness')
adapterManager.addDummyMethod(device, 'decreaseBrightness')
adapterManager.addDummyMethod(device, 'setNightMode')
adapterManager.addDummyMethod(device, 'setRGB')
adapterManager.addDummyMethod(device, 'setHex')
adapterManager.addDummyMethod(device, 'setHue')
adapterManager.addDummyMethod(device, 'setColor')
adapterManager.addDummyMethod(device, 'setColorBrightness')
adapterManager.addDummyMethod(device, 'getColor')
adapterManager.addDummyMethod(device, 'setDiscoMode')
return res
end,
process = function (device, data, domoticz, utils, adapterManager)
if (device.deviceSubType == 'RGBWW') or (device.deviceSubType == 'WW') then
function device.setKelvin(kelvin)
local url
url = domoticz.settings['Domoticz url'] ..
'/json.htm?param=setkelvinlevel&type=command&idx=' .. device.id .. '&kelvin=' .. tonumber(kelvin)
return domoticz.openURL(url)
function device.setWhiteMode()
local url
'/json.htm?param=whitelight&type=command&idx=' .. device.id
function device.increaseBrightness()
local url
'/json.htm?param=brightnessup&type=command&idx=' .. device.id
function device.decreaseBrightness()
local url
'/json.htm?param=brightnessdown&type=command&idx=' .. device.id
function device.setNightMode()
local url
'/json.htm?param=nightlight&type=command&idx=' .. device.id
function device.setDiscoMode(modeNum)
if (type(modeNum) ~= 'number' or modeNum < 1 or modeNum > 9) then
domoticz.log('Mode number needs to be a number from 1-9', utils.LOG_ERROR)
local url
'/json.htm?param=discomodenum' .. tonumber(modeNum) .. '&type=command&idx=' .. device.id
local function inRange(value, low, high)
return (value >= low and value <= high )
local function validRGB(r, g, b)
return (
type(r) == 'number' and
type(b) == 'number' and
type(g) == 'number' and
inRange(r, 0, 255) and
inRange(b, 0, 255) and
inRange(g, 0, 255)
local function RGBError()
domoticz.log('RGB values need to be numbers from 0-255', utils.LOG_ERROR)
function device.setRGB(r, g, b)
if not(validRGB(r, g, b)) then RGBError() return false end
local h, s, b, isWhite = domoticz.utils.rgbToHSB(r, g, b)
local url = domoticz.settings['Domoticz url'] ..
'/json.htm?param=setcolbrightnessvalue&type=command' ..
'&idx=' .. device.id ..
'&hue=' .. math.floor(tonumber(h) + 0.5) ..
'&brightness=' .. math.floor(tonumber(b) + 0.5) ..
'&iswhite=' .. tostring(isWhite)
function device.setColor(r, g, b, br, cw, ww, m, t)
if br and not(inRange(br, 0, 100)) then
domoticz.log('Brightness value need to be number from 0-100', utils.LOG_ERROR)
return false
if m == nil then m = 3 end
local colors = domoticz.utils.fromJSON(device.color,{ t=0, cw=0, ww=0})
local brightness = br or 100
if br == nil then
local _ , _ , brightness = domoticz.utils.rgbToHSB(r, g, b)
if cw == nil then cw = colors.cw end
if ww == nil then ww = colors.ww end
if t == nil then t = colors.t end
'/json.htm?type=command¶m=setcolbrightnessvalue' ..
'&brightness=' .. brightness ..
'&color={"m":' .. m ..
',"t":' .. t ..
',"cw":' .. cw ..
',"ww":' .. ww ..
',"r":' .. r ..
',"g":' .. g ..
',"b":' .. b .. '}'
function device.setColorBrightness(r, g, b, br, cw, ww, m, t)
return device.setColor(r, g, b, br, cw, ww, m, t)
function device.setHex(r,g,b)
local hex = string.format("%02x",r) .. string.format("%02x", g) .. string.format("%02x", b)
local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=command¶m=setcolbrightnessvalue' ..
'&hex=' .. hex ..
'&iswhite=false'
function device.setHue(hue,brightness,isWhite)
if not(brightness) or not(inRange(brightness, 0, 100)) then
return false
if not(hue) or not(inRange(hue, 0, 360)) then
domoticz.log('hue value need to be number from 0-360', utils.LOG_ERROR)
return false
if isWhite and type(isWhite) ~= "boolean" then
domoticz.log('isWhite need to be of boolean type', utils.LOG_ERROR)
return false
if not(isWhite) then isWhite = false end
'&hue=' .. hue ..
function device.getColor()
if not(device.color) or device.color == "" then
domoticz.log('Color field not set for this device', utils.LOG_ERROR)
return nil
local ct = domoticz.utils.fromJSON(device.color, {})
ct.hue, ct.saturation, ct.value, ct.isWhite = domoticz.utils.rgbToHSB(ct.r, ct.g, ct.b)
ct.red = ct.r
ct.blue = ct.b
ct.green = ct.g
ct["warm white"] = ct.ww
ct["cold white"] = ct.cw
ct.temperature = ct.t
ct.mode = ct.m
ct.brightness = ct.value
return (ct)
