Or Or Or optimized?  [Solved]
Solderbro
Domoticz version: 2020.1
Or Or Or optimized?
Post by Solderbro »
trying to optimize and shorten programs here, but sometimes i'm out of ideas. Is it possible to shorten this script that raise up heating at 3 points in the week?
if heizpause == 'Heizen' then
print('Modus Bad aktualisieren')
if (t.matchesRule('at 04:45 on mon, tue, wed, thu, fri') or ('at 16:05 on mon, tue, wed, thu, fri') or ('at 06:30 on sat, sun')) then
spirit.updateMode('Heat')
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
Hydci
Domoticz version: 4.10717
Re: Or Or Or optimized?
Post by Hydci »
Hello I think you can do like that, maybe someone will have another idea :)
        on =
            timer     = { 'at 04:45 on mon, tue, wed, thu, fri','at 16:05 on mon, tue, wed, thu, fri','at 06:30 on sat, sun'},
            devices = {'heizpause'},
    execute = function( dz, item)
    if item.isTimer then
Solderbro
Re: Or Or Or optimized?  [Solved]
Post by Solderbro »
Uhm i just realized that such OR statements won't work at all. It seems not to be possible to optimize that, so every statement requires single elseif statement to run.
This one updates at 09:05 and 21:30.
if (t.matchesRule('at 09:05')) then
spirit.updateMode('Heat Eco')
elseif (t.matchesRule('at 21:30')) then
print('Bad Sparmodus gesetzt')
While this one never update the mode, don't know if the line is malformed at all.
print('Modus Kueche aktualisieren')
if (t.matchesRule('at 04:50 on mon, tue, wed, thu, fri') or ('at 15:15 on mon, tue, wed, thu, fri') or ('at 07:30 on sat, sun')) then
print('Küche Heizmodus gesetzt')
Conclusion: Never use Or statements?
Solderbro wrote: Wednesday 30 October 2019 20:30 Conclusion: Never use or statements?
or... if you like short code:
t.matchesRule = tm
if  tm('at 04:50 on mon, tue, wed, thu, fri') or tm('at 15:15 on mon, tue, wed, thu, fri') or tm('at 07:30 on sat, sun') then
