usage of setKelvin  [Solved]
pipiche
usage of setKelvin
Post by pipiche »
When using the setKevin( temp ) function to set a device operated via a python plugin, it looks like a brightness value is given.
Where thise brightness value is coming from ?
here after is the simple dzVent script
        active = true,
                ['timer'] = {
                        'every minute',
        execute = function(dz, Item, info)
                local lamp = dz.devices( 'DIN-Zigate - ColorControlWW-90fd9ffffe86c7a1-01')
                lamp.setKelvin(80)
if then you enable debug in your python plugin, you'll see in the onCommand the following information:
Command: Set Color
Level: 86
Color: {"b":0,"cw":51,"g":0,"m":2,"r":0,"t":204,"ww":204}
The question is , where Level is coming from as it is not set in the setKelvin function
PS/
Re: usage of setKelvin
pipiche wrote: Tuesday 29 October 2019 11:23 When using the setKevin( temp ) function to set a device operated via a python plugin, it looks like a brightness value is given.
Where this brightness value is coming from ?
I checked the dzVents setKelvin method but do not see this behavior.
A dz.devices(156).setKelvin(10) does a
http://127.0.0.1:8084/json.htm?param=setkelvinlevel&type=command&idx=156&kelvin=10
behind the scenes. On my system (V4.11403) that does not influence the level / brightness.
pipiche
Post by pipiche »
waaren wrote: Tuesday 29 October 2019 14:30
Waaren, is your device based on a Native plugin, or a Python plugin ?
pipiche wrote: Tuesday 29 October 2019 14:34 @waaren, is your device based on a Native plugin, or a Python plugin ?
It's a native plugin (Hue) but for as far dzVents is used to execute the setKelvin that does not make a difference to the url send.
There is only one setKelvin method available in dzVents and it use the same URL for all devices for which it is available.
You can look in <domoticz dir>/dzVents/runtime/device-adapters/rgbw_device.lua where you will find
		if (device.deviceSubType == 'RGBWW') or (device.deviceSubType == 'WW')  then
			function device.setKelvin(kelvin)
				local url
				url = domoticz.settings['Domoticz url'] ..
						'/json.htm?param=setkelvinlevel&type=command&idx=' .. device.id .. '&kelvin=' .. tonumber(kelvin)
				return domoticz.openURL(url)
pipiche
Post by pipiche »
My worry is that indeed there is only one API on the dzVent, but the way it is translated by the Python Framework might be different.
Why I'm saying that is because the onCommand() method called when a command is made receive 2 parameters, Level and Color.
If the Level is not part of the setKelvin(), where is it coming from
Re: usage of setKelvin  [Solved]
pipiche wrote: Tuesday 29 October 2019 15:04 My worry is that indeed there is only one API on the dzVent, but the way it is translated by the Python Framework might be different.
dzVents only interacts with domoticz. Probably better to ask this in a Python framework sub-forum.
pipiche
Post by pipiche »
@Waaren, yep I did it.
Follow-up on https://www.domoticz.com/forum/viewtopi ... 65&t=29949
