How to swipe between screens on a Windows 10 touchscreen ? Topic is solved
Hi Dashticz community,
I'm giving a try at Dashticz and I love the simplicity and possibilities. I designed a 2 screens dashboard. When I'm testing it on my desktop, I "drag and drop" to switch between screens, fine.
I tested the same on my Teclast TBook T11 tablet running on Windows 10. No matter which web browser I use, Chrome, Firefox, Edge, swiping does not switch between screens.
I understand swiping on a touchscreen is simulating window scrolling and this could be the root cause why it does not swipe cause it requires a drag and drop.
I did not find anything at the OS level to change the touchscreen swipe behaviour.
Does anybody use a Windows 10 touchscreen and can provide some solution or workaround ?
Can dashticz react to "scroll event" to make the switch between screens possible ?
jaaap
Re: How to swipe between screens on a Windows 10 touchscreen ?
I had the same problem and solved it by enlarging the navigation buttons on the bottom, so I can click them easily and they take me to the next screen
I shouldn't have mentioned workaround as accepted in my request
Thanks for the suggestion though I'm looking for a working swipe
jaaap
Haha, to be honest: I would rather like a real solution as well. Following your topic!Masure wrote: Monday 28 October 2019 20:37 I shouldn't have mentioned workaround as accepted in my request
Lokonli
I don't have a win10 touch device. My Android tablet is working fine.jaaap wrote: Monday 28 October 2019 21:01Haha, to be honest: I would rather like a real solution as well. Following your topic!Masure wrote: Monday 28 October 2019 20:37 I shouldn't have mentioned workaround as accepted in my request
I expect the touch/mobile device detection doesn't work reliably. Dashticz uses a very old library for this.
Could you do some testing:
In the file js/main.js, line 478, (latest master and beta) you read:
if (md.mobile() == null || md.tablet() !== null) {
if (true) {
I just tried.
=> Gives the same result.
To see what is changing, I also tried
=> It puts the 2 screens visible with a scrollbar.
if (true ) {To see what is changing, I also tried
if (false)Re: How to swipe between screens on a Windows 10 touchscreen ?
The latest swiper (4.5.1) fixes swiping on windows 10 tablet. I just made a drop in replacement of vendor\swiper folder.
The issue was referenced on the swiper github : https://github.com/kidjp85/react-id-swiper/issues/230
However the navigation buttons are lost.
Lokonli
Should be solved in the latest beta v3.2.0
Can you confirm?
Can you confirm?
jaaap
Confirmed! Works perfect on my W10 tablet. Thanks!Lokonli wrote: Saturday 09 November 2019 14:24 Should be solved in the latest beta v3.2.0
Can you confirm?
