OSRAM Smart+ multicolor (multicolour) bulb reverting to previous colour
pocock
Post by pocock »
I've got an OSRAM Smart+ E27 multicolor bulb
I can control the colours using Domoticz
If I select a colour, after a few minutes, it reverts to the colour it had when it was turned on.
E.g. if it is white when I turn it on, then I select red, then some minutes later it goes back to white.
Daniel Pocock, Debian Developer
https://danielpocock.com
pipiche
Re: OSRAM Smart+ multicolor (multicolour) bulb reverting to previous colour
Post by pipiche »
Daniel, not sure but are you controlling it via Zigate ? If so do you see anything happening in the Logs ?
mpx2
Domoticz version: 4.10717
Post by mpx2 »
I have ZigBee Certified OSRAM SMART+ Classic E27 Tunable White buld. It doesn't work with Zigate but works with Samsung Smartthings Hub, Philips Hue and Cozify hub. Osram should work with ZigBee certified product.
I updated the firmware to version 3.1a and updated Domoticz plugin to the latest version.
pipiche
Post by pipiche »
@mpx2
It should work with zigate, don’t see any reason why not.
Please when you’ll do the pairing with zigate and plugin. Provides the log file
EDITED
When you say it doesn't work, what do you mean ?
After the pairing, do you get widget created in Domoticz are nothing
What do you have in the logs file ?
pipiche
Post by pipiche »
mpx2 wrote: Sunday 01 December 2019 15:00 I have ZigBee Certified OSRAM SMART+ Classic E27 Tunable White buld. It doesn't work with Zigate but works with Samsung Smartthings Hub, Philips Hue and Cozify hub. Osram should work with ZigBee certified product.
