Switch off afer 1 minute fails, where is problem in this script  [Solved]
HvdW
Domoticz version: 2023.2
Post by HvdW »
I have this switch which I want to go to state OFF 1 minute after it is switched ON
I have been searching this forum and wasn't able to find the answer.
Help in correcting the script is appreciated.
		devices = {
			'My_switch'
	execute = function(domoticz, TriggeredItem)
		domoticz.log('Device ' .. TriggeredItem .. ' was changed', domoticz.LOG_INFO)
		if (TriggeredItem) then -- state == 'On'
			TriggeredItem.switchOff().afterMin(1) -- if it is a switch
			domoticz.notify('Light info', 'The light ' .. TriggeredItem.name .. ' will be switched off soon')
Bugs bug me.
Re: Switch off afer 1 minute fails, where is problem in this script
HvdW wrote: Monday 28 October 2019 0:10 I have this switch which I want to go to state OFF 1 minute after it is switched ON
Can you try this ?
return
    on =
        devices =
            'My_switch'
        if TriggeredItem.active then -- state == 'On'
            domoticz.log(TriggeredItem.name .. ' is now switched off.', domoticz.LOG_INFO)
HvdW
Re: Switch off afer 1 minute fails, where is problem in this script  [Solved]
Post by HvdW »
.active that's it!
Thanks a lot!
Bugs bug me.
