Back again...
Bought another Trädfri light bulb and a motion sensor. I managed to get the light in deCONZ and the Phoscon app. But how do I push the new light to Domoticz? I have set Domoticz to allow for new devices for 5 minutes. But nothing comes in.
Conbee/deCONZ push new device
Thorgal789
- Target OS: -
Re: Conbee/deCONZ push new device
Hello, again ^^.
If you have the light in phoscon.
- If you have an old plugin version, restart the plugin (Setting/hardware/deconz/update), it will resynchronize.
- if you have a recent version, just use the bulb in phoscon.
If it don't work, enable log 'debug info only' and use the first method, you will have informations on log panel.
Plantje
Thanks for replying. I think I have the most recent plugin version. Hitting "update" to resynchronize always works? That gives me the feeling I am more in control.
Yesterday I did a reboot and I started working with the light in Phoscon for some time. And I set Domoticz to accept new devices. And at some point the bulb was there all of a sudden.
What I thought was weird: yesterday I had to go to port 8090 in Phoscon and after a reboot I had to go to port 80 again... weird stuff!
Thorgal789
- Target OS: -
Sure, the "update" buton still work, but now every time the plugin see a new device, it can add it itself (if domoticz autorise it).
You can set yourself port in configuration, but it's the port 80 by defaut, except if the port is already taken by other app. How have you find the new port ? You are using the buton in deconz ?
