Action LSC Smart Connect lights and sensors?
- FearNaBoinne
- Domoticz version: 2021.1
Does anyone have any Action LSC Smart Connect ("Powered by Tuya") light-bulbs (colorchanging, dimming and/or on/off options available), sensors, remotes or smart sirens connected to Domoticz?
I've tried searching, but "LSC" is too short and "Action" too generic...
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
AllesVanZelf
- Domoticz version: 12467
Re: Action LSC Smart Connect lights and sensors?
- FearNaBoinne
I just tried adding one of the smartplugs, and successfully retrieved ID and key, but am now getting:
Error: (Plug): Async Read Exception (192.168.164.169:6668): 104, Connection reset by peer
(The address is confirmed via tcpdump, the dhcp-leases and the wifi management, so that's not the issue, and the DevID from the tuyapi proxy matched the reported DevID in the app...)
I can switch it on/off using the app!
Interesting enough, an NMAP scan *does* show 6668 as open:
# nmap -Pn -sT 192.168.164.169 -p 1-9999
Starting Nmap 7.01 ( https://nmap.org ) at 2019-09-13 17:34 CEST
Nmap scan report for 192.168.164.169
Host is up (0.0031s latency).
Not shown: 9988 closed ports
PORT STATE SERVICE
23/tcp filtered telnet
53/tcp filtered domain
111/tcp filtered rpcbind
139/tcp filtered netbios-ssn
443/tcp filtered https
445/tcp filtered microsoft-ds
1025/tcp filtered NFS-or-IIS
1723/tcp filtered pptp
3306/tcp filtered mysql
6668/tcp open irc
8888/tcp filtered sun-answerbook
Nmap done: 1 IP address (1 host up) scanned in 58.06 seconds
PORT STATE SERVICE
6668/tcp open irc
AllesVanZelf
That what I found out
and that how I found the Tuya thread.
I have a light bulb. That one is not working yet. But the plug should work with the version in above thread.
Link
Have you tried the github plugin for the plug?
Link
- FearNaBoinne
That's the one I am using!
Wilco
- Domoticz version: 3.8153
Do you have a complete installation instruction for me? So i can use the LSC devices from the Action
- FearNaBoinne
Well, as you can see, we never got them to work... I returned them!
deennoo
LSC ude tuya 3.3 actual Tuya Plugin doesn't allow to choose which version to use
You have to update pytuya to 7.0.4 and force plugin to use tuya 3.3.
be join Tuya Plugin discution : https://www.domoticz.com/forum/viewtopic.php?t=22528
http://domo-attitude.fr
- FearNaBoinne
Got it to work with 3.3...
Will continue in the other thread...
Purchased two doorsensors and try to get IT to work with DomoticzFearNaBoinne wrote: Sunday 08 September 2019 13:46 Does anyone have any Action LSC Smart Connect ("Powered by Tuya") light-bulbs (colorchanging, dimming and/or on/off options available), sensors, remotes or smart sirens connected to Domoticz?
Is there a easy solution?
And how fast does the sensor trigger?
flash the devices to tasmota and they all work with domoticz
i flasht the ledstrip and now the power plug.
and they working
and they working
- FearNaBoinne
Is there an easy how to for flashing these to tasmota somewhere?
- FearNaBoinne
Found Tuya-convert OTA flasher and successfully reflashed a smart plug to Tasmota... Works like a charm! Going to test with one of their filament bulbs next, and also have the RGBW lightsrips to test with...FearNaBoinne wrote: Monday 20 January 2020 22:38 Is there an easy how to for flashing these to tasmota somewhere?
- rolandbreedveld
Dit anybody get the proxy part for sniffing the id's working:
https://github.com/codetheweb/tuyapi/bl ... s/SETUP.md
all the steps went fine, but at step 6
the TuyaSmart app, gives a network unavailable error on my iphone
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
- FearNaBoinne
Works fine for me every time...
The error does happen on the phone, that's ok though, as the proxy terminates once it has the IDs... The phone side isn't interesting, it's what the prxy output shows that is...
- FearNaBoinne
BTW, I now have 2 (former) LSC RGB Strips, 1 (former) LSC filament bulb E17 and 1 (former) LSC plug converted to Tasmota...
I have also this issue. The first 5 steps work, I can install and trust the certificate, but then I pull down in the app when connected to the proxy, I get an network error. The ID's and Keys won't show up eighter. Anyone who can help?rolandbreedveld wrote: Thursday 30 January 2020 21:59 Dit anybody get the proxy part for sniffing the id's working:
- FearNaBoinne
Any errors shown at the proxy-app side?
What phone, os, etc.?
Any usedul Information you can think of to include, include it... None of us have magic crystal balls!
- rolandbreedveld
No errors at the proxy side,FearNaBoinne wrote: Friday 31 January 2020 11:24 Any errors shown at the proxy-app side?
Any usedul Information you can think of to include, include it... None of us have magic crystal balls!![]()
I installed tuya-cli both on a Rapsberry Pi and a Linux pc
client running on an iPhone and an a android 5 phone
al the same issue
doing stacktracing of tuya-cli, I see more communication, with the android, but not the info we need
- rolandbreedveld
which plugin do you use to talk with tasmoto devices?FearNaBoinne wrote: Friday 31 January 2020 1:05 BTW, I now have 2 (former) LSC RGB Strips, 1 (former) LSC filament bulb E17 and 1 (former) LSC plug converted to Tasmota...
