give philips hue light a color
Frankseijts
Post by Frankseijts »
this is my first day of dzVents script and after some ours i did get my lamp on and of but now i want color to
this is my script
    active = true,
        timer = {
            'at 15:00-15:01',
    execute = function(domoticz, dummy)
        domoticz.devices('Hue color lamp 3').toggleSwitch()
        domoticz.myLight('Hue color lamp 3').setRGB(124, 233, 11)
can some one help me
Re: give philips hue light a color
Frankseijts wrote: Sunday 20 October 2019 15:11 I did get my lamp on and of but now i want color to
I don't understand why you used myLight but maybe this is what you intended ?
    active = true,
        timer = {
            'at 15:00-15:01',
    execute = function(domoticz)
          myHueLamp = .devices('Hue color lamp 3')
          myHueLamp.toggleSwitch()
          myHueLamp.setRGB(124, 233, 11)
If you start with a new script and it is not working as expected it can help to switch on debug loggging in the script and look at the log what happens during execiuion.
It would then look like
    active = true,
        timer = {
            'at 15:00-15:01',
logging =
        level = domoticz.LOG_DEBUG,
        marker = "Hue light test",
Frankseijts
Thank jou very much,
I did chose mylight because wen i was seaching the web to find out how i can get color to my lamp.
i was reading that in a new update of dzVents mylight was the trigger to set collor
but i wil look at the log wat happend wit the logging in the script
Frankseijts
i did use the script
but this is the error what i get
2019-10-21 21:01:00.492 Error: dzVents: Error: (2.4.29) Hue light test: ...omoticz/scripts/dzVents/generated_scripts/Hal - Hue3.lua:16: attempt to call global 'devices' (a nil value)
i attempt to find the problem but i didnt find it
Frankseijts wrote: Monday 21 October 2019 21:04 i did use the script
:oops: My bad. domoticz fell off in my Copy/paste action. new one with domoticz included :)
    active = true,
        timer = {
            'at 15:00-15:01',
logging =
          myHueLamp = domoticz.devices('Hue color lamp 3')
Frankseijts
Thanks waaren
this was good
but now i was thinken lets turn on a group
so i replaced devices into groups and Hue collor lamp 3 into Hal ( the hue color lamp 3 is in the group hal)
but the i did get this massage
Hue3.lua:18: attempt to call field 'toggleSwitch
so do i have to do something with toggleSwitch
on the wiki page i read this
groups = { ...}
A list of one or more group-names or indexes. The same rules as devices apply.
so i was thinking how hard can i be :0)
Frankseijts wrote: Tuesday 22 October 2019 21:10 on the wiki page i read this
groups = { ...}
I guess you need to read a bit further on the wiki page. You will find which methods are available for group objects.
Frankseijts
Thanks waaren
i had to change Domoticz.Groups('hal') into Domoticz.groups('hal')
