Send notifications to android app  [Solved]
snellejellep
Post by snellejellep »
i want to send notifications to the domoticz android app, would like to certain phones only but all of them will also be ok.
i currently have this, i found it on the forum over here.
dz.notify("ALARM!", "sensor" .. device.name .. "heeft beweging gedetecteerd!", dz.PRIORITY_EMERGENCY,dz.SOUND_DEFAULT, "" , dz.NSS_GOOGLE_CLOUD_MESSAGING)
which does not seem to work.
anyone a suggestion what will work?
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
Re: Send notifications to android app
snellejellep wrote: Friday 18 October 2019 21:27 i want to send notifications to the domoticz android app, would like to certain phones only but all of them will also be ok.
Syntaxis is OK. Did you set GCM active in the [setup][settings][notification] tab and pressed the test button ?
snellejellep
waaren wrote: Saturday 19 October 2019 1:38 Syntaxis is OK. Did you set GCM active in the [setup][settings][notification] tab and pressed the test button ?
yes, that is turned on and sending a test message that way works too.
snellejellep wrote: Saturday 19 October 2019 16:57
Can you share the complete script and log ? That might help in identifying why the notify does not work as expected.
snellejellep
sure, this is the script:
		devices = {
			'PIR*',
			'beweging brug',
			'Deur*',
			'roldeur'
	execute = function(dz, device)
		local brug          = dz.devices("beweging brug")
		local security      = dz.devices("Domoticz Security Panel").state
		local announce      = dz.variables("Announce")
	    if security == "Arm Away" then
	        announce.set("Er is beweging gedetecteerd door ".. device.name .."")
	    elseif security == "Arm Home" then
	        if brug.lastUpdate.secondsAgo < 5 then
and this is my log output:
2019-10-19 17:43:53.874 Status: dzVents: Info: Handling events for: "PIR schuurzolder", value: "On"
2019-10-19 17:43:53.874 Status: dzVents: Info: ------ Start internal script: Alarm away dzvents: Device: "PIR schuurzolder (Dummy/virtual)", Index: 799
2019-10-19 17:43:53.881 Status: dzVents: Info: ------ Finished Alarm away dzvents
snellejellep wrote: Saturday 19 October 2019 17:46 sure
Can you try this ?
return
    on =
        devices =
            'PIR*',
            'beweging brug',
            'Deur*',
            'roldeur',
            -- 'myTrigger',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'secure notify',
        dz.log('Security state: ' .. dz.security,dz.LOG_DEBUG)
        dz.log('Device ' .. device.name .. ' lastUpdate was ' .. device.lastUpdate.secondsAgo .. ' seconds ago',dz.LOG_DEBUG)
        if dz.security == dz.SECURITY_ARMEDAWAY then
            announce.set("Er is beweging gedetecteerd door ".. device.name )
        elseif dz.security == dz.SECURITY_ARMEDHOME then
snellejellep
Re: Send notifications to android app  [Solved]
that works, thank you verry much!
