add data to table  [Solved]
pvklink
Domoticz version: latest b
add data to table
Post by pvklink »
Somebody knows how to add data/record to:
local testdata ='{"veld1": "waarde 1","veld2": "waarde 2"}'
for example by:
testdata.add("veld3": "waarde 3")
        active = true,
            devices = {'test'}
        data = {
            switchevents = { initial = {} }
    execute = function(dz, item, info)
    function deepdump( tbl )
            local checklist = {}
            local function innerdump( tbl, indent )
                checklist[ tostring(tbl) ] = true
                for k,v in pairs(tbl) do
                        print (indent .. tostring(k) .. " ===> value: ".. tostring(v)  )
                    if (type(v) == "table" and not checklist[ tostring(v) ]) then
                        innerdump(v,indent .. tostring(k) .. ".")
            innerdump( tbl, "Key: " )
    -- how to add "veld3": "waarde 3" to testdata
    local myTable   = dz.utils.fromJSON(testdata)
    deepdump(myTable) -- use this function call to see the structure of your table
Jablotron connection, Ikea
Re: add data to table
pvklink wrote: Saturday 19 October 2019 14:55 Somebody knows how to add data/record to:
There is more then one way to do this. Have a look at this:
        active = true,
        on = { devices = {'test', 'myTrigger'}},
    execute = function(dz, item)
    local testJSON  ='{"key1": "value 1","key2": "value 2"}'
    local testTable =   {
                            ["key3"] = "value 3",
                            ["key4"] = "value 4",
    local myTable   = dz.utils.fromJSON(testJSON)
    -- merge tables
    for k,v in pairs(testTable) do myTable[k] = v end
    local varName   = "key 8"
    local varName2  = { ["key 9"] = "value 9" }
    myTable.key5 = "value 5" -- method 1. Only allowed for string keys without spaces in name
    myTable["key 6"] = "value 6" -- method 2 (necessary when something else as a string without spaces)
    myTable[7] = "value 7" -- method 3 numeric key
    myTable[varName] = "value 8" -- method 4 using content of a variable as key
    myTable[9] = varName2 -- method 5 add a sub-table
    dz.utils.dumpTable(myTable)
pvklink
Post by pvklink »
Ok, Thanks!
two more questions :D
1. When i dont know the number of records in the table, is there a command to add it 'as the latest' (becasue you define a recordnumber) or do i read the table first and count the number of records?
2. the solution must have the option to store some names and values that belong together as a record like:
[{"ident": "aaaa", "var1": "1", "var2": "1"},{"ident": "zzzz", "var1": "2", "var2": "1"}]
and then add: ,{"ident": "bbbbb", "var1": "1", "var2": "7"}]
Re: add data to table  [Solved]
pvklink wrote: Monday 21 October 2019 9:58 1. When i don't know the number of records in the table, is there a command to add it 'as the latest' (because you define a record-number) or do i read the table first and count the number of records?
dzVents (=Lua) tables are key/value containers but can also be treated like an array.
t = {"a", "b", "c"} This is a syntax shortcut for t = {[1]="a", [2]="b", [3]="c"}
1.
If your table is build like an array with only consecutive numbers starting at 1, you can query the number of records in the table with #tablename
If the table is build with other keys or with gaps in the numbering or not starting with 1 then you will need to loop through the table the get the number of records. with something like the getTablePairsCount function in the next answer
2.
local function getTablePairsCount(t)
   local tableCounter = 0
   for k,v in pairs(t) do
       tableCounter = tableCounter + 1
   return tableCounter
local function tableValuesToString(t,sep)
   local myString = ''
   local sep = sep or ',' -- default separator = ,
   for k, v in pairs(t) do
        if type(v) == 'string' then
            myString = myString .. v .. sep
   if myString ~= '' then  return myString:gsub("[" .. sep .. "]*$",'') end -- return concatenated string after removing last separator
local rTable = {}
local record1 = '{"ident": "aaaa", "var1": "1", "var2": "1"}'
local record2 = '{"ident": "zzzz", "var1": "2", "var2": "1"}'
local record3 = '{"ident": "bbbbb", "var1": "1", "var2": "7"}'
rTable[1] =  record1
rTable[#rTable + 1] =  record2
rTable[#rTable + 1] =  record3
print ('there are ' .. getTablePairsCount(rTable) .. '  records in the table') -- works on all tables
print ('there are ' .. #rTable .. '  records in the table') -- gives only a valid answer on pure array like tables
print ('[' .. table.concat(rTable,',') .. ']') -- table concat only concatenates the values within the pure array part of the table (with key 1,2,3,..)
rTable[0] = '{"ident": "00000", "var0"=": "0", "var00": "00"}'
rTable['negen'] =  '{"ident": "999999", "var9"=": "9", "var99": "99"}'
print ('there are now ' .. getTablePairsCount(rTable) .. '  records in the table')
print ('there are now more then '  .. #rTable .. '  records in the table') -- #rTable does not give the count of all records now only the ones in the pure Array
print('\n\n')
print ('Values from pure array part of the table ==>>  [' .. table.concat(rTable,',') .. ']')  -- this does not print all the table values
print ('Values from complete table ==>> [' .. tableValuesToString(rTable,',') .. ']')
pvklink
Post by pvklink »
Thank you very much, something to play with the next coming weeks!
This is exactly what i meant!
