2019-10-14 16:52:58.387 Status: PluginSystem: Started, Python version '3.7.4'.Moderator: leecollings
2019-10-14 16:52:58.387 Status: PluginSystem: Started, Python version '3.7.4'.Code: Select all
pip3 install requestsThanks for your reply, much appreciated.Thorgal789 wrote: Friday 18 October 2019 15:50 Hello,
It's a request problem, I think there is a problem in the url, perhaps bad config in plugin setting.
Pls enable debug level "debug info only", just before theses lines you will have something like "making request .........." , can you show me this line.
This url need to work in a browser, if you want to make test.
For theses ones who have problems with API Key, there is a file called API_KEY.py to help you to create/delete/get list with command line, informations and commands inside the file. It can too give somes informations like your used websocket port. To have all commands or parameters just use:
python3 API_KEY.py
And for theses ones who don't know where to find the API key and don't wana use the tool: https://dresden-elektronik.github.io/de ... uireapikey
cd /home/pi/domoticz/plugins/Domoticz-deCONZCode: Select all
luke@Holly:~/dev-domoticz/plugins$ python3 -V
Python 3.4.3Code: Select all
luke@Holly:~/dev-domoticz/plugins$ dpkg --get-selections | grep libpython
libpython-dev:i386 install
libpython-stdlib:i386 install
libpython2.7:i386 install
libpython2.7-dev:i386 install
libpython2.7-minimal:i386 install
libpython2.7-stdlib:i386 install
libpython3-dev:i386 install
libpython3-stdlib:i386 install
libpython3.4:i386 install
libpython3.4-dev:i386 install
libpython3.4-minimal:i386 install
libpython3.4-stdlib:i386 installCode: Select all
Version: 4.10726
Build Hash: be79a17
Compile Date: 2019-05-10 10:37:55
dzVents Version: 2.4.19
Python Version: NoneCode: Select all
2019-10-19 07:53:52.062 Status: Domoticz V4.10726 (c)2012-2019 GizMoCuz
2019-10-19 07:53:52.063 Status: Build Hash: be79a17, Date: 2019-05-10 10:37:55
2019-10-19 07:53:52.063 Status: Startup Path: /home/luke/dev-domoticz/
2019-10-19 07:53:52.083 Status: Philips Hue: Using default poll interval of 10 secs.
2019-10-19 07:53:52.087 Status: WebServer(HTTP) started on address: :: with port 8082
2019-10-19 07:53:52.090 Status: WebServer(SSL) started on address: :: with port 443
2019-10-19 07:53:52.091 Status: RxQueue: queue worker started...
2019-10-19 07:53:52.091 Status: TCPServer: shared server started...
2019-10-19 07:53:54.095 Status: Hardware Monitor: Started
2019-10-19 07:53:54.139 Status: RFXCOM: Worker started...
2019-10-19 07:53:54.139 Status: Philips Hue: Worker started...
2019-10-19 07:53:54.140 Status: EventSystem: reset all events...
2019-10-19 07:53:54.141 Status: EventSystem: reset all device statuses...
2019-10-19 07:53:54.152 Status: EventSystem: Queue thread started...
2019-10-19 07:53:54.152 Status: EventSystem: Started
2019-10-19 07:53:55.169 Status: RFXCOM: Using serial port: /dev/ttyUSB0Users browsing this forum: Bing [Bot] and 1 guest
