require function in dzvents  [Solved]
Maxx
Post by Maxx »
I am trying to build my own "function library" and I found some examples but I have not succeeded in implemting them.
following sample :
		timer = {'every minute'},
    logging =   {   level                   = domoticz.LOG_DEBUG,
                    marker                  = "Object test" },
	execute = function(dz, triggeredItem)
    local function Functions()
        fn = require("Functions")
    if pcall(Functions) then
        dz.log("Functions loaded",dz.LOG_DEBUG)
        local status, err = pcall(Functions)
        dz.log("\n\n ********   Error  ********* \n\n       " .. err .. "\n\n" , dz.LOG_ERROR)               -- No Functions -->> we quit
        dz.log("Required functions (file) unusable or not present", dz.LOG_ERROR)                                   -- No usersettting file So we quit
        dz.log("Vereiste functies kunnen niet worden geladen. Verwerking stopt.", dz.LOG_ERROR)      -- No usersettting file So we quit
        return
    local set = 20
    local diff = 18
    local output = fn.PID(set, diff)
    dz.log('PID output : ' .. output)
and this is the function:
local self = { }
function round(n)
      return n % 1 >= 0.5 and math.ceil(n) or math.floor(n)
function self.PID(setpoint, avg_Temp)
        local Ki = 10
        local Kp = 13,6
        local Kd = 1000
        local dt = 60
        local error = setpoint - avg_Temp
        local output = (Kp*error+22)
        return output
it gives the following log:
 2019-10-13 20:44:00.891 Status: dzVents: Info: Object test: ------ Start internal script: test:, trigger: every minute
2019-10-13 20:44:00.891 Status: dzVents: Debug: Object test: Functions loaded
2019-10-13 20:44:00.892 Status: dzVents: Info: Object test: ------ Finished test
2019-10-13 20:44:00.891 Error: dzVents: Error: (2.4.29) Object test: An error occurred when calling event handler test
2019-10-13 20:44:00.891 Error: dzVents: Error: (2.4.29) Object test: ...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:37: attempt to index global 'fn' (a boolean value)
Loading the function is succesfull but instead of executing the function it doesn't see fn as a reference to the function but as a boolean.
Is there anybody that has tried this before ( I took the example of the buienradar script, it seems to work in this script bu I cannot find the difference.)
Re: require function in dzvents  [Solved]
Maxx wrote: Sunday 13 October 2019 20:49 I am trying to build my own "function library" and I found some examples but I have not succeeded in implemting them.
The last line of the function file should be
return self
Maxx
Re: require function in dzvents [SOLVED]
Post by Maxx »
Hi Waaren,
Thank you, it works
