Fibaro Heat Controller
samuelAN
Post by samuelAN »
Hello!
I just got back my heat controllers updated to last firmware 4.5
I installed them in domoticz. A good news is that even if you don't have external temperature sensor, now the internal valve temperature is listed in the domoticz devices ! (This was not the case before...)
I will test the temperature regulation now...
The issue I have is that polling is necessary in order to get updated values of set point and internal temperature.. and if polling is not enable, the node will be rapidly marked as dead by domoticz! With polling enabled, I am afraid for the battery drain...
Someone has experience to share with this device?
Kanarie
Re: Fibaro Heat Controller
Post by Kanarie »
Hi Samuel,
I'm thinking of buying new Fibaro Heat Controllers and I would like to know how yours are behaving? Does it drain the battery with polling enabled?
