Controlling Toon [HACKED] from Domoticz
Plantje
Re: Controlling Toon [HACKED] from Domoticz
Post by Plantje »
Is the first post of this thread being updated if needed? Or should I go through the whole thread to find updates?
martjah
Post by martjah »
Anyone else having issues with crashing Domoticz on latest version with Toon Sync enabled?
When i enable the LUA for the Toon Sync, Domoticz crashes with a fatal error. When i disable the Toon sync, domoticz keeps working.
The previous stable (2018) was working stable for 6 months+
Micha123
Post by Micha123 »
hi, i have rooted my ton, now i have a little problem within domoticz en virtual thermostat. if i change the temperatur on toon itself, that wil be fine updated inndomoticz, but everytime domoticz update the temp sets on toon, it triggers it also to toon back.
so if i switch on toon from away to home, the temp wil be set to 21 degrees,
now the values are updated in domoticz and domoticz send after update the virtual thermostat 21 to toon, now on toon is the scene changed from home to "tijdelijk"
thats my scritps.
toon.
timer = {
'every minute'
execute = function(domoticz)
local ToonThermostat = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
local ToonBoilerTempIn = domoticz.variables('UV_ToonboilerInTempName').value -- Sensor showing water temp return
local ToonBoilerTempOut = domoticz.variables('UV_ToonboilerOutTempName').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonboilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonboilerModulationLevel').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value
-- local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value
-- local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value -- Sensor showing current boiler set point water temp out
-- Handle json
local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
-- JSON data from Toon contains a extra "," which should not be there.
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
-- local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
-- local GasPowerInfo = handle4:read('*all')
-- handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
-- local jsonGasPower = json:decode(GasPowerInfo)
-- domoticz.log(jsonGasPower)
-- local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
-- local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
-- local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
-- local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
-- local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
-- local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
-- local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
-- local CurrentElectricityDeliveredLaag = 0
-- local CurrentElectricityDeliveredHoog = 0
-- local totalDeliveredPower = 0
-- domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
-- domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
-- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- Update the Boiler water Out to current value
local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
-- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
-- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away<br> elseif currentActiveState == 4 then currentActiveState = 60 -- Holiday
-- Update the toon burner selector to current program state
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan<br> elseif currentBurnerInfo == 3 then currentBurnerInfo = 10 -- voorverwarmen volgend setpoint
if CurrentToonBurnerValue ~= currentBurnerInfo then -- Update toon burner selector if it has changed
-- domoticz.log('Updating Toon burner info:')
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
-- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
-- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
-- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
-- Update the temperature sensor to current room temperature
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
-- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
-- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
-- Updates the toon auto program switch
if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
-- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
-- Updates the toon program information text box
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
and setpoint
timer = {
'every minute'
-- Handle json
handle:close()
return
handle2:close()
-- handle4:close()
Ok, i solved it.
Abother queation is it possible to run dzVent script every 15 ssconds?
OedzesG
Post by OedzesG »
Micha123 wrote: Tuesday 10 September 2019 20:42 Ok, i solved it.
Would you mind telling me how you solved it? stil fighting with this problem.. and silend() isnt working for me! :cry:
EdwinK
Post by EdwinK »
What is the latest version of the script? Going through this site (and another) I see several scripts for a rooted/hacked Toon, and I'm getting a bit (loads) confused.
Micha123
Post by Micha123 »
make an new integer user variable
UV_ToonChangedByDomoticz
set 0 on the variable
in the domoticz script add following
change it to
domoticz.variables('UV_ToonChangedByDomoticz').set(1)
delete yout setpoint scritp
add a lua script triggered by device
-- Script used for Toon Thermostaat utility device, upon changing temp in Domoticz, temperature is sent to Toon.
ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
ToonIP = uservariables['UV_ToonIP']
for deviceName,deviceValue in pairs(devicechanged) do
if (deviceName == ToonThermostatSensorName) then
if uservariables['UV_ToonChangedByDomoticz'] == 1 then
commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
SetPoint = otherdevices_svalues[ToonThermostatSensorName]
ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
print('Setting Toon setpoint to '.. SetPoint)
commandArray['OpenURL'] = ToonCommand
your done, now if your change the setpoint on toon itself it update the status in domoticz, but dont trigger it
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
EdwinK wrote: Tuesday 01 October 2019 10:59 What is the latest version of the script? Going through this site (and another) I see several scripts for a rooted/hacked Toon, and I'm getting a bit (loads) confused.
This is my latest script with a lot of functionalities. Just comment out what you do not need and adjust to your own system settings
Toon_script
   logging = {
      level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
      marker = "-=# P1 Toon #=-"
      timer = {
         'every minute'
        local ToonThermostat        = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
        local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpoint').value  -- Sensor showing current boiler set point water temp out
-- Handle json
        -- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")()  -- For Linux (ClearOS)
        handle:close()
            return
        handle2:close()
        handle4:close()
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":")
-- Update the powerconsumption
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow )           --stroomverbruik momenteel hoogtarief
         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow )           --stroomverbruik momenteel laagtarief
         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity)    --stroomverbruik totaal hoogtarief
         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity)    --stroomverbruik totaal laagtarief
         local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity)   --stroomgeleverd momenteel hoogtarief
         local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity)   --stroomgeleverd momenteel laagtarief
         local CurrentElectricityQuantity =   CurrentElectricityFlowHoog + CurrentElectricityFlowLaag       --stroomverbruik totaal aktueel
         local totalDeliveredPower2 = CurrentElectricityDeliveredHoog/1000 + CurrentElectricityDeliveredLaag/1000      --stroomverbruik totaal geleverd
         local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
         local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
        --domoticz.log('*** P1 from toon: ' .. CurrentElectricityQuantityLaag/1000 .. 'kwh USAGE1 | ' ..CurrentElectricityQuantityHoog/1000 .. 'kwh USAGE2 | ' .. CurrentElectricityDeliveredLaag/1000 .. 'kwh RETURN1 | ' .. CurrentElectricityDeliveredHoog/1000 .. 'kwh RETURN2 | ' .. CurrentElectricityQuantity .. 'w consumed | '.. totalDeliveredPower2 .. 'w produced', domoticz.LOG_FORCE)
        currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp))  -- afgeronde getallen is voldoende [PdB]
        currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp))  -- afgeronde getallen is voldoende [PdB]
--      currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure))  -- 1 decimaal is voldoende [PdB]
            domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure, domoticz.LOG_INFO)
-- Update the current temperature setpoint
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
              currentTemperature = tonumber(string.format("%.1f", currentTemperature))  -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
-- Update the current scene by state
-- Update the current scene by temperature
		local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
		    if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort
		elseif currentActiveTemp == 19.5 then currentActiveState = 30 -- Home
		elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep
		elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away
		else	currentActiveState = 50 -- Manual
            elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
Toon_setpoint
		devices = {
			'Toon Thermostaat'
		domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', domoticz.variables('UV_ToonIP').value, device.setPoint*100))
				domoticz.log('Setting Toon setpoint to '.. device.setPoint)
EdwinK
Post by EdwinK »
Going to work on it this weekend.
bertbigb
Post by bertbigb »
madpatrick wrote: Friday 04 October 2019 21:01 This is my latest script with a lot of functionalities.
Toon_script
CODE STARTS
 MORE CODE
Hi All,
I used this script from madpatrick
and I get the following error:
-=# P1 Toon #=-: ...moticz/scripts/dzVents/generated_scripts/Toon_Script.lua:64: attempt to index field 'dev_24' (a nil value)
What can I do to get this error message away? What are these dev_24, dev_25 and so on?
I hope someone can help me.
Best regards Bert
Synology DS1517+ - DSM 6.2
madpatrick
You need to check your dev_##
Go to [url]http://TOON_IP/hdrv_zwave?action=getDevices.json[/url] and check which number your Toon is having.
You can also disable these lines in the script if you do need/use them
bertbigb
Post by bertbigb »
Thanks for your help.
I asked the url and it tells me:
{"dev_settings_device": {"uuid": "2019bdae-5c8c-4d99-9a05-91be4b11c751", "name": "settings_device", "internalAddress": "settings_device", "type": "settings_device"}, "dev_5": {"uuid": "d763fc74-cd9b-48fb-9419-1b31d69269e8", "name": "HAE_METER_v2", "internalAddress": "5", "type": "HAE_METER_v2", "supportsCrc": "1", "ccList": "22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "supportedCC": "22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "nodeFlags": [], "IsConnected": "1", "DeviceName": "HAE_METER_v2", "CurrentSensorStatus": "UNKNOWN"},
"dev_5.1": {"uuid": "e866b59c-dec0-40c8-a32b-8dc21c2d49e3", "name": "HAE_METER_v2_1", "internalAddress": "5.1", "type": "gas", "supportsCrc": "0", "ccList": "3c 3d 3e 72 86", "supportedCC": "3c 3d 3e 72 86", "nodeFlags": [], "CurrentGasFlow": "0.00", "CurrentGasQuantity": "1655616.00", "DeviceName": "HAE_METER_v2_1", "CurrentSensorStatus": "OPERATIONAL"},
So I changed the dev_2 from the original code to dev_5 (what is the case for me) like the following:
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_5.", "dev_5")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_5:", "dev_5\":")
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_52.CurrentElectricityFlow )           --stroomverbruik momenteel hoogtarief
And now everything is fine.
I thought to do good to explain it what I did so if someone runs into the same problem he/she knows how to solve also.
Thanks for helping me!
Best regards Bert
madpatrick
The problem is that every Toon is a little bit different somehow.
Also not everybody is using all the options provided, so need to tweak the script which is applicable.
The best way is to add some comments in the script, since searching in the forum post is difficult (they are to long at a certain point or split up)
I've added already some comments, but there is always room for improvement :roll:
Peebee01
Domoticz version: 4.1071
Post by Peebee01 »
Hi, Im new here but managed with all the great instructions here to get my toon to work with Domoticz.
However, Im running domoticz on a windows PC thats always on as a mediacenter and I have the impression that the lua script doesnt work properly on windows as the values it retrieves from the Toon are not copied to the user variables in Domoticz.
I do have the json.lua file and I’ve modified the script to change the path to it, and the script executes without any errors in my domoticz log file.
Just was just wondering does anyone have the script of @madpatrick working on a windows machine? If so any pointer in the right direction you could give me?
Is there a way to modify the script to write more details into the log? After reading the thermostat info, json is used to decode the information and update the user variables. Can I add the option to write the “ThermostatInfo” to the log before and after json:decode?
Peebee01
Post by Peebee01 »
found my mistake, I didnt have curl.exe in my PATH .... making some progress
madpatrick
Peebee01 wrote: Thursday 10 October 2019 8:14 s there a way to modify the script to write more details into the log? After reading the thermostat info, json is used to decode the information and update the user variables. Can I add the option to write the “ThermostatInfo” to the log before and after json:decode?
You can set the logging on DEBUG level in the script.
Peebee01
Post by Peebee01 »
Thanks but it doesnt provide a lot more info.
Keep getting every function to return an error message “...can not index a nil value”
Ive use madpatricks scripts on a windows pc
   logging = {
      level = domoticz.LOG_INFO, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
      timer = {
         'every minute'
-- Handle json
       -- local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")()  -- For Linux (ClearOS)
      json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
        handle:close()
            return
        handle2:close()
        handle4:close()
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_3.", "dev_3")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_3:", "dev_3\":")
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_34.CurrentElectricityFlow )           --stroomverbruik momenteel hoogtarief
         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_36.CurrentElectricityFlow )           --stroomverbruik momenteel laagtarief
         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_34.CurrentElectricityQuantity)    --stroomverbruik totaal hoogtarief
         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_36.CurrentElectricityQuantity)    --stroomverbruik totaal laagtarief
         local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_35.CurrentElectricityQuantity)   --stroomgeleverd momenteel hoogtarief
         local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_37.CurrentElectricityQuantity)   --stroomgeleverd momenteel laagtarief
         local CurrentGasFlow = tonumber(jsonGasPower.dev_31.CurrentGasFlow)
         local CurrentGasQuantity = tonumber(jsonGasPower.dev_31.CurrentGasQuantity)
The error message I get is:
 2019-10-11 20:52:00.147 Status: dzVents: Debug: Dumping domoticz data to C:\Program Files (x86)\Domoticz\scripts\dzVents\domoticzData.lua
2019-10-11 20:52:00.149 Status: dzVents: Debug: Event triggers:
2019-10-11 20:52:00.149 Status: dzVents: Debug: - Timer
2019-10-11 20:52:00.169 Status: dzVents: Info: -=# P1 Toon #=-: ------ Start internal script: Script #6:, trigger: every minute
2019-10-11 20:52:00.307 Status: dzVents: Error (2.4.19): -=# P1 Toon #=-: There is no device with that name or id:
2019-10-11 20:52:00.307 Status: dzVents: Error (2.4.19): -=# P1 Toon #=-: An error occured when calling event handler Script #6
2019-10-11 20:52:00.307 Status: dzVents: Error (2.4.19): -=# P1 Toon #=-: ...Domoticz\scripts\dzVents\generated_scripts/Script #6.lua:75: attempt to index a nil value
2019-10-11 20:52:00.307 Status: dzVents: Info: -=# P1 Toon #=-: ------ Finished Script #6
I created the script in Domoticz using: dzVents -> Timer. Is that correct or should this be a Lua script?
If I comment out the function on row 75, the same error occurs for the P1 gas meter, but in order to eliminate that the device ID I also commented out that one only to get the next function to complain about indexing a nil value.
So I feel there is something more fundamentally wrong. I did install curl.exe and placed it in the windows path. Is there perhaps another program needed? Starting to get lost on what is wrong so I hope someone could point me in the right direction
madpatrick
Do you have also created the Uservariables with the same names and also de devices ?
Peebee01
Post by Peebee01 »
Hi madpatrick,
Would you mind posting your user variables? I’ve got all I believe, but could be worth checking.
Regarding the devices, I did not understand how the devices and the user variables are linked in domoticz. The names arent identical in all cases, right? So how does a user variables update a device?
madpatrick
Peebee01 wrote: Friday 11 October 2019 21:03 Hi madpatrick,
20 UV_P1SmartMeterGasMeterStand String P1 Gas
19 UV_P1SmartMeterElectra String P1 Elektra
18 UV_ToonBoilerModulation String ModulationLevel
13 UV_ToonBoilerPressure String Keteldruk
12 UV_ToonBoilerTempOut String Ketel Temp UIT
11 UV_ToonBoilerTempIn String Ketel Temp IN
10 UV_ToonBurnerName String Ketelstand
9 UV_ToonBoilerTempSetpoint String Ketel Setpoint
8 UV_DomoticzIP String 192.168.1.1:9200
7 UV_ToonProgramInformation String Toon Information
6 UV_ToonAutoProgram String Toon Auto Program
4 UV_ToonScenes String Toon Scenes
3 UV_ToonTemperature String Temperatuur Kamer
2 UV_ToonIP String 192.168.1.200
1 UV_ToonThermostat String Toon Thermostaat
Sorry for the layout....
Peebee01
Post by Peebee01 »
Deleted all my user variables and recreated them based on your list.
Could you also share your devices?
Finally; the scripts are dzVents and not LUA scripts when creating them in Domoticz, right?
