Maybe dzVents is to difficult for me. Again copy from video fail.  [Solved]
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Again is taking an example from the video not working. 16:56
The difference's is the name of the device in the way that I have a space in that name.
Also I have skipped the log part.
		devices = {
			'Lichtsensor Binnen'
	execute = function(domoticz, 'Lichtsensor Binnen')        <-- error
		if ('Lichtsensor Binnen'.state == 'On') then
		    local KSR = domoticz.devices('Kamer Schoorsteen Rechts')
		   KSR.switchOn()
2019-10-07 17:40:17.898 Status: EventSystem: reset all events...
2019-10-07 17:40:17.900 Status: dzVents: Write file: C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts\4 mei.lua
2019-10-07 17:40:17.901 Status: dzVents: Write file: C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts\Lichtsensor binnen.lua
2019-10-07 17:40:49.416 Status: dzVents: Error (2.4.19): error loading module 'Lichtsensor binnen' from file 'C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts/Lichtsensor binnen.lua':
2019-10-07 17:40:49.416 ...scripts\dzVents\generated_scripts/Lichtsensor binnen.lua:7: <name> or '...' expected near ''Lichtsensor Binnen''
(BTW why is also write my 4 mei.lua script every time.)
This make me not looking smart. :')
Bear with me, English is not my native language.
domogijs
Re: Maybe dzVents is to difficult for me. Again copy from video fail.
Post by domogijs »
Try },
execute = function(domoticz, Lichtsensor Binnen)
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
KroontjesPen wrote: Monday 07 October 2019 18:05 Again is taking an example from the video not working. 16:56
The
execute = function()
Is what it claims to be; a function.
it's a function with the name execute and with 0-3 parameters.
The 1st. parameter is the domoticz object which is a table with all devices, uservars, settings, etc
The 2nd. parameter is the object that triggered the script. So in this case a device with all of its attributes and connected functions.
The 3rd parameter is an object with some additional information. Not relevant for this script. If you are interested you can find the details in the wiki
so if you use
dzVents (Lua) will try to interpret the parameters as described above but cannot handle a quoted string as parameter and presents you the errormessage.
I always use the call with parameters dz and item
execute = function(dz, item)
dz because I am too lazy to type domoticz many times and item because I often use multiple triggers for a script like devices and timers and httpResponses. In the script body you can figure out what triggered the script by structures like
if item.isDevice then
  do stuff
elseif item.isTimer then
  do otherStuff
If you are not feeling comfortable yet with dzVents maybe start by searching the internet for "Lua getting started"
or go directly to the official Lua page
Lua is not difficult to learn but without any programming experience the way it uses tables might feel a bit overwhelming.
domogijs wrote: Monday 07 October 2019 18:19 execute = function(domoticz, Lichtsensor Binnen)
@domogijs, this is not going to work; Lua does not allow a space in a parameter name.
KroontjesPen
Nope. ;)
2019-10-07 19:07:00.187 Status: dzVents: Error (2.4.19): error loading module 'Lichtsensor binnen' from file 'C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts/Lichtsensor binnen.lua':
2019-10-07 19:07:00.187 ...scripts\dzVents\generated_scripts/Lichtsensor binnen.lua:7: ')' expected near 'Binnen'
KroontjesPen wrote: Monday 07 October 2019 19:29 2019-10-07 19:07:00.187 Status: dzVents: Error (2.4.19): error loading module 'Lichtsensor binnen' from file 'C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts/Lichtsensor binnen.lua':
As described in my previous post try
		devices = {
	execute = function(domoticz, item) -- item is here the device 'Lichtsensor Binnen' with all of it attributes and functions
		if (item.state == 'On') then
		    KSR.switchOn()
KroontjesPen
Lichtsensor Binnen is a normal switch with on/off. (KaKu/COCO type.)
What is then difference between 'Living' and 'Lichtsensor Binnen' the space.
How do we overcome this.
KroontjesPen
In the back of my head I know the risk that a name of a device could have. Misspelling is easy to make.
This is my solution:
    		devices = {
    			idx = 25
    	execute = function(domoticz, idx )
            local ksr = domoticz.devices('Kamer Schoorsteen Rechts')
    		if (idx.state == 'Off') then
    		   ksr.switchOff()
		   elseif (idx.state == 'On') then
    		   ksr.switchOn()
Kaku/COCO reacting little later. ;)
From here I hope to put delay timers and cancelQueuedCommands(): Function.
The question about saving my 4 mei.lua script every time this script get saved is still open.
 How get this with more scripts.
KroontjesPen wrote: Monday 07 October 2019 22:41 This is my solution:
I am sorry to be the messenger of bad news but your solution will not do the job. Lua does not understand the idx = 25 the way you expect and will not trigger the script if device 25 changes state. If you want that to happen you will have to change that part to
on =
    devices =
         25
domogijs
Post by domogijs »
waaren wrote: Monday 07 October 2019 19:25
Thanks! I did not notice
Greets Gijs
KroontjesPen wrote: Monday 07 October 2019 22:41 The question about saving my 4 mei.lua script every time this script get saved is still open.
If you use the domoticz internal editor, the scripts are stored in the domoticz database. dzVents needs to access the scripts from an OS level to be able to process them. Because there is no way for the event system to know which files are not touched on the OS level the choice is made to write all scripts from the database to the OS level every time the event system is reset. A reset is generated by a number of events, one of them being saving a script from the internal editor.
If you don't want that during testing of a new script every time you save an updated version, you can write your scripts with an external editor and store them in the directory
<domoticzdir>/scripts/dzVents/scripts with the extension .lua
KroontjesPen
waaren wrote: Tuesday 08 October 2019 0:05 I am sorry to be the messenger of bad news but your solution will not do the job. Lua does not understand the idx = 25 the way you expect and will not trigger the script if device 25 changes state. If you want that to happen you will have to change that part to
But ...
wiki/DzVents https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#Device_object_API wrote:
Writing scripts
devices = { ... }
A list of device-names or indexes. If a device in your system was changed (e.g. switch was triggered or a new temperature was received) and it is listed in this section then the execute function is executed. Each device can be:
The name of your device between string quotes. You can use the asterisk (*) wild-card here e.g. PIR_* or *_PIR. E.g.: devices = { 'myDevice', 'anotherDevice', 123, 'pir*' }
The index (idx) of your device (as the name may change, the index will usually stay the same, the index can be found in the devices section in Domoticz). Note that idx is a number;
Device attributes and methods for all devices
id: Number. Index of the device. You can find the index in the device list (idx column) in Domoticz settings. It's not truly an index but is unique enough for dzVents to be treated as an id.
idx: Number. Same as id: index of the device
Domoticz attributes and methods
devices(idx/name): Function. A function returning a device by idx or name: domoticz.devices(123) or domoticz.devices('My switch'). .....
Is that wiki not trusted then?
KroontjesPen wrote: Tuesday 08 October 2019 7:35 Is that wiki not trusted then?
Sorry but you misunderstand what you red. You can use the name of the device within quotes like 'keukentafel licht' or you can use the device id number like 123 without quotes. You tried
    		devices = {
    			idx = 25
and that is not what's in the wiki.
KroontjesPen
Re: Maybe dzVents is to difficult for me. Again copy from video fail.  [Solved]
Flowing your advice I looked up by Lua and found this and it's working. :D
3.4 – Concatenation
Lua denotes the string concatenation operator by ".." (two dots). If any of its operands is a number, Lua converts that number to a string.
print("Hello " .. "World") --> Hello World
print(0 .. 1) --> 01
rreturn {
    		devices = {
                Dev = "Lichtsensor " .. "Binnen"
    	execute = function(domoticz, Dev )
            local Doel = domoticz.devices('Kamer Schoorsteen Rechts')
    		if (Dev.state == 'Off') then
    		   Doel.switchOff()
		   elseif (Dev.state == 'On') then
    		   Doel.switchOn()
BTW that IS the dzVents wiki
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Edit:
Make the script more flexible to use for other scripts.
For testing I can set -- for Dev and Doel and put others on a new line.
