[Solved] Cannot see device in Domoticz
exhortae
Post by exhortae »
I'm trying to use a new wall switch that I bought.
I'm using a raspberry pi 3 model B+, mosqitto as a broker and zigbee2mqtt.
I already have connected a gledopto led bulb and I can control it using domoticz (so I know that my setup is working correctly :) )
When I connect the switch, I can see that it is recognized in zigbee2mqtt
see following log
zigbee2mqtt:info 10/5/2019, 9:13:16 PM Currently 2 devices are joined:
 zigbee2mqtt:info 10/5/2019, 9:13:16 PM 0x00124b001c432b78 (0x00124b001c432b78) : GL-B-008Z - Gledopto Smart 12W E27 RGB / CW LED bulb (Router)
 zigbee2mqtt:info 10/5/2019, 9:13:16 PM 0x00158d000291dd66 (0x00158d000291dd66) : HGZB-42-UK / HGZB-41 - Nue / 3A Smart switch 1 or 2 gang (Router)
 zigbee2mqtt:warn 10/5/2019, 9:13:16 PM `permit_join` set to  `true` in configuration.yaml.
It seems like the zemismart wall switch is just a chinese version of 2-UK / HGZB-41 - Nue / 3A Smart switch.
The problem that I have is that I don't see the switch in domoticz device panel, I tried to add it with no success.
If anyone can help. Thank you
exhortae
Re: Cannot see device in Domoticz
Post by exhortae »
Nevermind, I added the following line
'HGZB-42-UK / HGZB-41': OnOffSwitchAdapter, # Nue / 3A Smart switch 1 or 2 gang
to the file
/domoticz/plugins/zigbee2mqtt/adapters/__init__.py
and it worked
Buteo72
Re: [Solved] Cannot see device in Domoticz
Post by Buteo72 »
Thanks, above helped me a lot with my WaterValve "CR Smart Home TS0001"
https://www.zigbee2mqtt.io/devices/TS0001.html
