* New config setting 'start_page' to set Dashticz start page number
* New parameter 'scrollbars' to set scrollbars in frame.
* New graph module. It’s not completely backwards compatible. Especially styling will be different.
Fixes
* Faster initial display of the Dashticz dashboard.
i dont get it.
i'm in the beta brance on git ,copy the git url ,clone this to my pi(sudo git clone https://github.com/Dashticz/dashticz.git) but stil on the master 3.0.6 branche
Gianni wrote: ↑Wednesday 18 September 2019 21:31
i dont get it.
This should install the beta: git clone https://github.com/Dashticz/dashticz --branch beta
Or you can change to beta: git fetch origin
git checkout beta
git pull
gianni@domotic:/var/www/html/homecontrol $ git fetch origin
gianni@domotic:/var/www/html/homecontrol $ git checkout beta
M .gitignore
M Dockerfile
M Makefile
M README.md
M css/creative.css
M custom/custom.css
M custom/custom.js
M docs/blocks/buttons.rst
M docs/blocks/domoticzblocks.rst
M docs/blocks/specials/publictransport.rst
M docs/blocks/specials/weather.rst
M docs/customcss/customcss.rst
M docs/dashticzconfiguration.rst
M docs/develop/documentation.rst
M docs/gettingstarted/automaticinstall.rst
M docs/gettingstarted/manualinstall.rst
M docs/releasenotes.rst
M docs/tipsandtricks.rst
M index.html
M index2.html
M js/blocks.js
M js/news.js
M js/publictransport.js
M js/settings.js
M js/version.js
M js/weather_owm.js
M scripts/dashticz_install.sh
M version.txt
Already on 'beta'
Your branch is up-to-date with 'origin/beta'.
gianni@domotic:/var/www/html/homecontrol $ git pull
Already up-to-date.
git clone the beta to a folder and then copied the file to my homecontrol folder without the custom folder.
now i am on beta 3.1.0
JimmyH1969 wrote: ↑Tuesday 24 September 2019 10:47
Thanks for the update, i was still on V2
Is it still possible to resize a graph? In V2 i could do this in the custom.css:
the position of the title in the button. I have a tablet on the wall and my buttons only have numbers in it. They are a little of to the left, not in the center, so i want the title (in my case just a number) a bit more to the right.
With a block i can do something like this:
Whats the different beween V2 and V3?
I did à manual install of V3 and it works on my pc and newest iPad. I also have a old iPad wich I use on the wall.
On this one V3 isnt working, I get the loadingpage and then nothing. On V2 it works like a charme.
I use Safari because I cant install Chrome because the iPad is running on iOS 9. I also clear the cache.
Lokonli wrote: ↑Saturday 05 October 2019 17:48
Did you use v3 beta or master?
Beta contains some es6 functionality which probably gives issues on older safari versions.
Thanks, i use the beta. I will try the master.
I think i've fixed it with the latest changes on github (beta branch). Can you test it?
Yes the page will load, but my buttons won't work I use
