I followed the http://www.domoticz.com/wiki/Linux to install Domoticz, but I want to uninstall it. Can you just remove the directories or are there special things you have to take care of?
Uninstall Domoticz from Linux
ebretteville
- Domoticz version: 2.3530
Re: Uninstall Domoticz from Linux
I'll be interested also to get an answer because I installed it on LMDE and now, I need at each login to type the command...
Thanks guys
startxThanks guys
paulvha
If you want to remove Domoticz:
delete the Domoticz directory
( in case you had installed for automatic start)
- remove in /etc/init.d : domoticz.sh
- also check the directories /etc/rcx.d ( x = 1 - 6) for S or K files with domoticz
Not sure how this is integrated with StartX, I have both running in parallel without depending on each other.
marigo
- Domoticz version: 2020.2
Ok, will try that and report back when it's gone.
Edit:
I installed domoticz as root so in home directory eg /root/
Reloaded and everything looks ok in syslog.
Thx paulvha!
Edit:
rm -r domoticz/
rm -r open-zwave/
rm -r open-zwave-read-only
Thx paulvha!
febalci
Also don't forget to handle /etc/systemd/system/domoticz.service. First stop the service, disable it and delete it.
