Accurate, queryable wall thermostat?
brucez
Post by brucez »
I have a working heating solution where I can adjust the temperature by rooms. Every room has TRVs and wall thermostats. I have also installed Mi Home Temperature sensors, in order to have more accureate temperature readings.
Now, the problem is the following:
The wall thermostats are TKB TZ10.36 types. As an interface for adjusting the setpoint, they are great, but their temperature sensors are very inaccurate. (It can be even +3/-3 celsius)
The Mi Home temp&hum sensors are only sending updates in about 50 minutes intervals. Or in case of significant (0.5) temperature change.
Are there any wall thermostats on the market, that can be queried, accurate and have 0.1 resolution? (preferably Z-Wave)
galinette
Re: Accurate, queryable wall thermostat?
Post by galinette »
The "secure" ones have a good reputation. The design is not fancy though.
https://www.domotique-store.fr/fr/domot ... 4-zw-.html
