Switching from KaKu/COCO to Z-wave gives problems NOT a Z-wave problem [closed] Topic is solved
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Version: V4.10717 b386b49e5
Platform: Windows 10
RFXtrs433E Version: Ext2/1025
Z-Stick Gen 5 Version: 1.4.3244.gbb874f6a.dirty
Fibaro Wall Plug 5x
The simple start with the 5 wall-plug's turn out to be very stressful.
Switching on/off on the tab Light/Switches go's fine but using the timer won't.
Lucky I noticed this in the night so I could them switch off by myself.
They also overflowing the log-file with kWh data while in the Device list they all set be NOT active, →
Therefore I could not see why the timers don't worked.
A timer set for testing gives no switching on the wall-plug.
This is maybe not true. There are test in progress now 2019-9-28.
For now I am back to KaKu and have pull them out of the socket so they are dead for the system.
Maybe I have to go to a Z-Wave Plus controller i.e. VeraPlus Z-wave Plus.
Edit:
Last edited by KroontjesPen on Tuesday 01 October 2019 10:57, edited 8 times in total.
Bear with me, English is not my native language.
KroontjesPen
Re: Switching from KaKu/COCO to Z-wave gives problems
For "on time" switching I have found in Blockly a solution.
Time for/after sun-rise/set I use very often but more tricky, maybe impossible, in Blockly.
Therefore I hope that this device timer problem is not Z-wave related.
KroontjesPen
Re: Switching from KaKu/COCO to Z-wave gives problems *3
The moment that I wrote the first post I was sure the devices, Fibaro wall plugs, has no turned on or off.
But because the huge amount is data they drop into the log-file looking back if the devices has no turned on or off was impossible.
This is a part of today.
Now I'm finished the working around Blockly events I was looking to describe the problems of the device-timer I found that it was working.
Switching one Fibaro wall plug on/off a couple of times with intervals of 1,5 and 10 minutes. That's going well.
The working around Blockly events are switch off and the local devices-timers are set.
Maybe I can take quick a picture of the log-file from the evening on switching devices.
KroontjesPen
Re: Switching from KaKu/COCO to Z-wave gives problems AGAIN !!
The post where I conclude that the timers where working have I deleted.
After the successful weekend test I placed the wall plugs on there places.
There was only 1 that reacted on the timer but only that time.
In the search of the problem I hit a wrong link in the Node management so I decided to going back from scratch.
With first exclude every device and also delete the Z-stick Gen5 out of Domoticz.
When every thing was setup again sadly no timer won't working and I don't no what to do now. :(
That it had happens before was thus true.
KroontjesPen
Working till midnight to looked at this problem.
New set timer rules sometimes worked mostly not.
The old ones still do.
Even on non Z-wave devices have this problem.
Trying this morning on a KaKu/COCO device an most new timer rules are not executed.
The only thing what I can still do is again remove all the Z-wave stuff and try the timers again.
KroontjesPen
It is thus NOT Z-wave related.
Therefore I shall start a new tread.
