Migrate zwave memory from Aeon Z-Stick to RaZberry
jin
Post by jin »
I'm looked already into forums and wiki, but I'm wasn't unable to find a quick guide.
I'm using Domoticz with Aeon Labs Z-Stick S2 and I need to transfer zwave network config dump to the new raZberry chip I installed into Rasberry, and then remove the usb stick.
What is the right procedure to follow to accomplish this?
Thank you in advance.
gizmocuz
Re: Migrate zwave memory from Aeon Z-Stick to RaZberry
Post by gizmocuz »
i think you can make the razberry a secondary controller, and use the transfer command from the openzwave setup
why would you do this?
jin
Post by jin »
I already configured my zwave devices using the Aeon USB Z-Stick, and now I purchased a RaZberry interface to replace the USB Stick, so I don't want reconfigure all my devices with the new chip.
But the automatic domoticz database backup doesn't contain the zwave chip config?
roblom
Post by roblom »
A bit off-topic but why did you change from the stick to the raZberry.
jin
Post by jin »
decrxgarage wrote:A bit off-topic but why did you change from the stick to the raZberry.
Not for functional reason, but just because I like to have the rasperry box well integrated and without any external usb stick that can be removed anytime :)
nisak
Post by nisak »
Hi.
I'm planning on doing the same change in my system. Did you use gismocus instructions, and did it work?
To you other guys, why are you so negative for the change to razberry, is it poorer than the z-stick?
For my sake i'm planning on the change to get z-wave+ functions.
randytsuch
Post by randytsuch »
I'm pretty sure the zwave device configuration is stored in the zwave controller, and not in the domoticz database.
When you pair devices with a controller, the controller saves the device information, so it can talk to that device.
gizmocuz
Post by gizmocuz »
It will not work... the old Aeotec does not have a backup option
The new Aeotec (zwave+) should have a backup option, as this is according the zwave+ spec
