Problem with deconz
czasas
Problem with deconz
Post by czasas »
Hello, today I bought conbee II and add xiaomi switch to it. After configuring deconz and adding hardware to domoticz , devices are no creating.
I have an error :
2019-09-26 20:51:35.685 Error: (Conbee) Wrong startup, retrying !!
Do you have aby idea where os the problem ?
Full logs:
2019-09-26 20:51:35.651 (Conbee) Pushing 'onHeartbeatCallback' on to queue
2019-09-26 20:51:35.670 (Conbee) Processing 'onHeartbeatCallback' message
2019-09-26 20:51:35.670 (Conbee) Calling message handler 'onHeartbeat'.
2019-09-26 20:51:35.670 (Conbee) onHeartbeat called
2019-09-26 20:51:35.670 (Conbee) ### Initialisation > config
2019-09-26 20:51:35.670 (Conbee) ### Request config
2019-09-26 20:51:35.670 (Conbee) Send Command /api/49F1F1BBE9/config/ with None (0 in buffer)
2019-09-26 20:51:35.670 (Conbee) Making Request : http://192.168.0.110:80/api/49F1F1BBE9/config/ with params None
2019-09-26 20:51:35.684 (Conbee) Request Return : {"UTC":"2019-09-26T18:51:20","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF04F2F2","datastoreversion":"60","dhcp":true,"factorynew":false,"fwversion":"0x00000000","gateway":"192.168.0.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.0.110","linkbutton":false,"localtime":"2019-09-26T20:51:20","mac":"d0:7e:35:00:e2:36","modelid":"deCONZ","name":"deconz","netmask":"255.255.255.0","networkopenduration":60,"panid":0,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":false,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2019-09-06T16:58:29","state":"noupdates"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"noupdates"},"swversion":"2.5.69","timeformat":"12h","timezone":"none","uuid":"5c297ffb-261a-4db3-8207-7c415b607c4e","websocketnotifyall":true,"websocketport":443,"whitelist":{"2923BE84E1":{"create date":"2019-09-26T16:51:36","last use date":"2019-09-26T18:41:04","name":"Phoscon#B980x1087"},"49F1F1BBE9":{"create date":"2019-09-26T17:36:13","last use date":"2019-09-26T18:51:20","name":"Domoticz"},"6CD6AE5290":{"create date":"2019-09-26T17:16:24","last use date":"2019-09-26T17:36:41","name":"Domoticz"},"DB3C870C3E":{"create date":"2019-09-26T10:10:01","last use date":"2019-09-26T11:12:37","name":"Phoscon#B1366x625"}},"zigbeechannel":0}
2019-09-26 20:51:35.685 (Conbee) Classic Data : {'replacesbridgeid': None, 'proxyport': 0, 'portalservices': False, 'name': 'deconz', 'timezone': 'none', 'websocketport': 443, 'swupdate': {'checkforupdate': False, 'text': '', 'updatestate': 0, 'devicetypes': {'lights': [], 'sensors': [], 'bridge': False}, 'notify': False, 'url': ''}, 'zigbeechannel': 0, 'portalconnection': 'disconnected', 'apiversion': '1.16.0', 'whitelist': {'49F1F1BBE9': {'name': 'Domoticz', 'create date': '2019-09-26T17:36:13', 'last use date': '2019-09-26T18:51:20'}, 'DB3C870C3E': {'name': 'Phoscon#B1366x625', 'create date': '2019-09-26T10:10:01', 'last use date': '2019-09-26T11:12:37'}, '2923BE84E1': {'name': 'Phoscon#B980x1087', 'create date': '2019-09-26T16:51:36', 'last use date': '2019-09-26T18:41:04'}, '6CD6AE5290': {'name': 'Domoticz', 'create date': '2019-09-26T17:16:24', 'last use date': '2019-09-26T17:36:41'}}, 'timeformat': '12h', 'rfconnected': False, 'backup': {'status': 'idle', 'errorcode': 0}, 'localtime': '2019-09-26T20:51:20', 'swupdate2': {'checkforupdate': False, 'install': False, 'autoinstall': {'updatetime': '', 'on': False}, 'lastchange': '', 'lastinstall': '', 'bridge': {'lastinstall': '2019-09-06T16:58:29', 'state': 'noupdates'}, 'state': 'noupdates'}, 'portalstate': {'outgoing': False, 'signedon': False, 'communication': 'disconnected', 'incoming': False}, 'uuid': '5c297ffb-261a-4db3-8207-7c415b607c4e', 'internetservices': {'remoteaccess': 'disconnected'}, 'panid': 0, 'modelid': 'deCONZ', 'ipaddress': '192.168.0.110', 'bridgeid': '00212EFFFF04F2F2', 'UTC': '2019-09-26T18:51:20', 'linkbutton': False, 'proxyaddress': 'none', 'swversion': '2.5.69', 'mac': 'd0:7e:35:00:e2:36', 'gateway': '192.168.0.1', 'factorynew': False, 'fwversion': '0x00000000', 'networkopenduration': 60, 'datastoreversion': '60', 'starterkitid': '', 'netmask': '255.255.255.0', 'websocketnotifyall': True, 'dhcp': True}
Thorgal789
Re: Problem with deconz
Post by Thorgal789 »
This is something normal, I m checking the firmware value value to check if deconz is running.
In your situation > "fwversion":"0x00000000" mean deconz is not ready, so the plugin wait for 10s, retry, and if all fine (10s is enought for deconz starting) continu the process.
If you have this error a second time, it's not normal, check if deconz is correctly running, or if your version is up to date.
BTW, I m sure you have some problem with your config, lot of error in your config, like ,"zigbeechannel":0
Are you using headless version or GUI version ? Have you already try to run Phoscon at least one time ?
emme
Domoticz version: latest
Post by emme »
i'm using deconz as a service not running the UI on the PI desktop...
I've seen the UI method sometimes hangs....
close the UI, and activate the deconz service
"We always done this way"
Thorgal789
He is right. it can hang on some system if somes applications are started before some other.
You can try too, wait for all is running, close deconz and restart it.
