Datareceiving stopped on 8 from 10 Sensors and on both RFXTRX and RFLink
mastadook
Domoticz version: 2022.1
Post by mastadook »
Yesterday 08.21 in the Morning, Domoticz stopps receiving Data from Temperature Sensors.
For the 2 that are still working it look like:
10335	RFLink01	1801	0	Xiron	Temp + Humidity	WTGR800	22.0 C, 61 %
not working anymore, this was the Last working entry:
10320	RFXCOM		4901	1	Heizung Bad	Temp + Humidity	Rubicson/IW008T/TX95	22.5 C, 51 %	6	2019-09-24 08:21:22
10321	RFLink01	4901	0	Xiron		Temp + Humidity	WTGR800			22.5 C, 51 %	-	2019-09-24 08:21:21
I changed nothing
Batteries are fineand nearly full
My first Idea was, RFXtrx is damaged, but both stopps receiving,
I can find the Sensors as new Devices and the old ones did also not receive new Data
What About:
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Pro2/1041, Noise: 127 dB
Noise 127DB, is that much? and if yes, how can it happen, is nothing chanded?
I was not at home, buyed nothing new, no news anywhere.
Maybe a neighbour?
Any Idea why this can happen?
Maybe Database damaged?
Please help, I have no Idea
Last edited by mastadook on Wednesday 25 September 2019 10:09, edited 2 times in total.
________________________________________________________________________
global chief of permanent lightning and strike detonator
b_weijenberg
Re: Datareceiving stopped on 8 from 10 Sensors and on both RFXTRX and RFLink
Post by b_weijenberg »
Check the battery of the 2 sensors that are still received. Some sensors will produce RF noise if the battery is almost empty.
Or one of these or another sensor is defect or filled with water and produces RF noise.
RFX-433, RFX-433EMC, RFX-868
mastadook
Post by mastadook »
b_weijenberg wrote: Wednesday 25 September 2019 10:01 Check the battery of the 2 sensors that are still received. Some sensors will produce RF noise if the battery is almost empty.
Ahh the thing with Water is a good Idea, I will check directly and disable all from Outside.
mastadook
Post by mastadook »
I found one with 99% Humidity and one with no Battery
The one with no Battery was no longer used, thats why I did find it directly.
I think one of the 2 Devices raise up the Noiselevel.
Now I receive Data again, so thank you for your Tipp and Help :D :D
Best Regards :)
