Problem with script not working with some of the triggers
wayfinder
Domoticz version: 4.11005
Post by wayfinder »
This script triggers but the light will only switch with the 'at 9:08' trigger.
I can tell its triggering at sunset and sunrise buy the dz.log('V mode OFF ' ) output in the log.
Any clues appreciated. Thanks in advance.
		['timer'] = {
			'at sunset',
			'at sunrise',
			'at 9:08'
	logging = {
            level = domoticz.INFO,
            marker = "FFL Random"
	execute = function(dz, trigger)
			local FFL = dz.devices(67)
			local RANDOM = 20
            local ON_MIN = 70
		    FFL.cancelQueuedCommands()
		if (dz.devices(34).state == 'Off') then
				FFL.switchOn().withinMin(RANDOM).forMin(ON_MIN)
Re: Problem with script not working with some of the triggers
wayfinder wrote: Saturday 21 September 2019 18:29 This script triggers but the light will only switch with the 'at 9:08' trigger.
Don't see any reason in this script why it should not do the random switchOn at sunset and at sunrise. Could be that the cancelQueuedCommands() at 9:08 or from another script kiks in before the withinMin() timer ends but hard to tell without analyzing the complete log and other scripts.
You can test that the switchOn() is activated at sunset / sunrise by removing the withinMin() part. If really important you can also switch on Debug mode in dzVents and domoticz.
BTW domoticz.INFO should domoticz.LOG_INFO
wayfinder
Post by wayfinder »
I think you are correct on the cancelQueuedCommands(). I'll see tonight. I had it in another script I started by copying this one and never removed it.
