Is there an issue with the documentation there? https://www.domoticz.com/wiki/User_variables#Lua
I ran a LUA time script, default one and added in the user var loop:When using user variables in Lua, keep in mind the following: variables are always stored as a string in the Domoticz database, regardless of their type. The variables are passed in arrays to Lua, at that point they will always be strings also.
for variableName,variableValue in pairs(uservariables) do
print( 'Variable: '.. variableName .. ' = "' .. variableValue .. '" (' .. type(variableValue) .. ')')
endTestVar is integer, TempMax is float. None of them are passed in LUA as string as indicated in the Wiki.2019-09-16 10:15:00.496 Status: LUA: Time based event fired
2019-09-16 10:15:00.497 Status: LUA: Variable: TestVar = "0" (number)
2019-09-16 10:15:00.497 Status: LUA: Variable: TempMax = "25.5" (number)
Is it a bug? Has the behavior changed recently and the documentation was not updated?
I tried with latest stable 4.10717 on Pi and on 4.11300 on Win.
This question comes from a topic on the french speaking domoticz forum, where an user tried to compare his integer user variable to '0', without tostring or tonumber anywhere. I quickly looked around and found nothing about it here and around.
I wanted to know the official stand on this. Thanks
