I'm trying to install Zigbee2MQTT, but at starting Zigbee2MQTT I get the error: Port is not open.
My knowledge is limited, so I hope someone can help me. I tried searching al kinds of websites and forums, but allas, no results so far. I don't even know if it's usb related, sniffer firmware related, nodejs related or whatever. Help is appreciated.
Current situation:
- sniffer CC2531 flashed as described on zigbee2mqtt.io
- sniffer connected to pc with Debian 9 Stretch (Virtualbox on a Windows 10 machine) at port /dev/ttyACM1
- all the software installed as described on zigbee2mqtt.io, including the latest versions of node (v10.16.3) and npm (6.9.0).
- domoticz, latest version installed (not relevant yet, but just to be shure)
- /opt/zigbee2mqtt/data/configuration.yaml output:
# Home Assistant integration (MQTT discovery)
homeassistant: false
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://localhost'
# MQTT server authentication, uncomment if required:
# user: my_user
# password: my_password
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyACM1
> [email protected] start /opt/zigbee2mqtt
> node index.js
zigbee2mqtt:info 9/16/2019, 11:58:48 AM Logging to directory: '/opt/zigbee2mqtt/data/log/2019-09-16.11-58-44'
zigbee2mqtt:info 9/16/2019, 11:58:49 AM Starting zigbee2mqtt version 1.6.0 (commit #e26ad2a)
zigbee2mqtt:info 9/16/2019, 11:58:49 AM Starting zigbee-shepherd
events.js:174
throw er; // Unhandled 'error' event
Error: Port is not open
at SerialPort.close (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:425:29)
at Znp.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/znp/znp.js:107:37)
at Generator.next (<anonymous>)
at /opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/znp/znp.js:7:71
at new Promise (<anonymous>)
at __awaiter (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/znp/znp.js:3:12)
at SerialPort.serialPort.open (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/znp/znp.js:103:45)
at SerialPort._error (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:197:14)
at binding.open.then.err (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:241:12)
Emitted 'error' event at:
at errorOrDestroy (internal/streams/destroy.js:107:12)
at SerialPort.onerror (_stream_readable.js:733:7)
at SerialPort.emit (events.js:198:13)
at SerialPort._error (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:199:10)
at process.nextTick (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:204:31)
at process._tickCallback (internal/process/next_tick.js:61:11)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/drijfhout/.npm/_logs/2019-09-16T09_58_49_938Z-debug.log
