Change font size of only one item
RduPre
Post by RduPre »
See attachemnt.
Schermafbeelding 2019-09-15 om 12.30.52.png (28.06 KiB) Viewed 669 times
I like to change the font size off only one block(the 'blue' data), what whatever I try it does not change.
Any help is more than welcome
var variables = {}
blocks['v1'] = {
switch: true,
title: 'Domoticz Uptime',
image: 'duptime.png',
width: 12
#newsTicker li {
font-size:20px !important;
.col-data span	{ font-size: 30px; margin-left: 25px; font-weight: 600; color: deepskyblue; font-variant: small-caps;}
/*.col-data .title 		{ font-size: 25px; margin-right: 25px; font-weight:220; color: dodgerblue;font-variant: small-caps;}*/
.containsicalendar {
.containsicalendar .items {
  font-size: 175%;
.publictransport div {
    font-size: 20px;
.title {
    font-size:20px;
#newsTicker li {
HansieNL
Re: Change font size of only one item
Post by HansieNL »
Can you try:
.block_v1 .value {
color: deepskyblue;
font-size: 20px;
Blah blah blah
RduPre
Post by RduPre »
HansieNL wrote: Sunday 15 September 2019 16:43 Can you try:
.block_v1 .value {
color: deepskyblue;
font-size: 20px;
Thanks for responding, but this has no effect.
HansieNL
Post by HansieNL »
RduPre wrote: Sunday 15 September 2019 17:41
.block_v1 .value {
color: deepskyblue;
font-size: 20px;
Did you put this code at the end of your off your custom.css?
Blah blah blah
RduPre
Post by RduPre »
At the end
RduPre
Post by RduPre »
But when I put it at the top it works
RduPre
Post by RduPre »
Thanks, I thought I tried that too, but glad it's solved now
Lokonli
Post by Lokonli »
RduPre wrote: Sunday 15 September 2019 18:15 But when I put it at the top it works
That's strange, because it doesn't matter where you put it (although a later css setting may overrule a previous one)
Normally this means there is an error in your custom.css.
This may be a '//' symbol (not supported in css) or a missing bracket.
