Pass2PHP
Trigun
- Domoticz version: 4.10717
Re: Pass2PHP
Hi Guys,
for a while now Pass2php has been running very smoothly unitl yesterday.
my domoticz install crashed due to my SSD reaching its limit becauseof the backup job and the many logfiles.
I was able to delete alle thos files but now my phpmyadmin is not working anymore.
any ideas to restart it?
thanks in advance!
thanks in advance!
- Egregius
- Domoticz version: v2024.7
Re: Pass2PHP
Backup job? You don't do that on the device itself I would think.
Logfiles can be minimized, you can minimize the number of lg functions you call. Also for the domoticz log there are options. Also consider logrotation to keep the size of logfiles minimal.
Isn't there anything shown for phpMyAdmin, or something in the error log?
Trigun
Re: Pass2PHP
I found the cause. the backup copy job could not find the network repository.Egregius wrote: Monday 09 September 2019 16:30 Backup job? You don't do that on the device itself I would think.
therefor the proces could not be completed, which causes massive logfiles and a huge swapfile.
thx for the info regarding limiting the logfiles and even the logfile rotate option, am going to look at it.
ropske
- Domoticz version: V3_8394
Re: Pass2PHP
with what type of OS you installed these Sincze?
I have now a Raspberry Pi3b+ with image: 2019-07-10-raspbian-buster-lite
And when i'm doing the sudo apt-get install xxx what you said, I'm getting these errors:
- 1.jpg (73.6 KiB) Viewed 1705 times
Trigun
Re: Pass2PHP
Please check if Apache is running. Depending on the command Apache might also be installed and will get in the way of Nginx to workropske wrote:with what type of OS you installed these Sincze?
ropske
Re: Pass2PHP
i got this in response, so i guess it is running?
I need to remove it / disable it?
And then start again with the 'installation guide' from Sincze?
THank you
THank you
- 2.jpg (71.91 KiB) Viewed 1700 times
ropske
Re: Pass2PHP
and i'm getting this when i'm enter command: mysql -u root -p
i stopped the apache service by doing this command: sudo service apache2 stop
and when i want to go to phpmyadmin page it says forbidden:
- 4.jpg (18.74 KiB) Viewed 1699 times
Trigun
Re: Pass2PHP
Hi Robske,
See the file attached for a how to.
It took me a few times to get it right but I after getting it wrong all the time, I started to make a how to with all the info and help from the guys in this forum.
Hope you'll manage to get it working!
ropske
Re: Pass2PHP
thanks mate
i managed to install the database and all
when i want to check the values in devices, i get this error message: when i click: ignore all, i can see my values
Trigun
Re: Pass2PHP
Great, good to hear!ropske wrote: Sunday 29 September 2019 20:53 thanks mate
Do you have spaces or other unnormal characters in your devicesnames?
ropske
Re: Pass2PHP
some underscores _
but for the rest i don't have strange characters
btw, i got these errors when i click on every column, even the ones that are standard in phpmyadmin
Trigun
Re: Pass2PHP
That should not happen. try to do it according to the how to.ropske wrote: Sunday 29 September 2019 21:07 some underscores _
it might help.
ropske
Re: Pass2PHP
ok, i will check.
i installed a motion sensor now, and i see its taking some time to switch on my lights in screenshot above its 4seconds, but i happened allready it was +-7seconds
this is what is in my motion.php
Trigun
Re: Pass2PHP
The how to also shows some optimizations so really check it as it will definitely help.ropske wrote:ok, i will check.
ropske
Re: Pass2PHP
btw,
what raspbian is preferred?
stretch lite or buster lite for raspberry pi3b+ ? or does it not matter?
my new ssd is arriving today, before i was running on an usb-stick, that will probably be the cause of my slow reaction speed?
Trigun
Re: Pass2PHP
I am using Stretch on a 3B+ropske wrote: Tuesday 01 October 2019 12:48 btw,
bare in mind, slow responses can have multiple reasons. I've had it as well and in my case it was due to a zwave connection issue.
I needed to add an extra wired device in order to expand my mesh network.
ropske
Re: Pass2PHP
almost all my zwave devices are wired
ropske
Re: Pass2PHP
when i want to install this:
Install MySQLserver
sudo apt-get install mysql-server
i get this error message: may i do:
sudo apt-get install mariadb-server-10.0
is there anything else that changes then?
thanks
Install MySQLserver
thanks
ropske
Re: Pass2PHP
btw, im running raspbian buster full on pi3b+
or is it better to run stretch?
- Egregius
Re: Pass2PHP
The current Debian version is 10 Buster, so best is to run that one.
