Smart Led Messenger
- laco
- Domoticz version: 2021.1
Smart Led Messenger
I bought Smart Led Messenger. Someone can tell me how to set them up in DOMOTICZ.
I want to see the temperature, the clock, the on / off switch, and more.
https://www.smartledmessenger.com
elmortero
- Domoticz version: 3.9639
Re: Smart Led Messenger
This Page (in French) says that you can send your text using
http://ip_address/?message=TEXT&intensity=AA&speed=BB
where ip_address is the ip of your messenger
TEXT = the text you want to display
AA = the brightness
BB = the scroll speed is the how fast your text moves
So, with this you can use your favorite scripting language to get the info from Domoticz and send it to the smart led messenger
AA = the brightness
- laco
Can also be used in blockly?
elmortero
I never tried that, but according to this topic https://www.domoticz.com/forum/viewtopic.php?t=17006 it should work
With dzvents and bash I could help you but not blockly.
- laco
Thank you it works for me perfectly. As it moves, it sends the text to the messenger and displays the digital clock sleep after 5 seconds.
Now I need to figure out how to send the temperature information. This may require a script.
- laco
Can you please create a script that sends temperature information every 5 minutes?
elmortero
The script I am posting is for dzVents.
I understand that you are not yet familiar with it so please read these hints from waaren
Please let me know if you know more command, I have ordered a Smart Led Messenger too
This script (change to match your setup):by waaren
using dzVents would be an option. See below how that could look like. From your profile I cannot see which domoticz version you use.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
More info on dzVents:
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
timer = { 'every 5 minutes'}
execute = function(domoticz, triggerItem)
local smart_led_ip = '192.168.1.28' --replace by the ip address of your smart led messenger
local static = 1 -- change to 0 if you want scrolling text
local sensor = domoticz.devices('thermometer') -- replace thermometer by the EXACT name of your sensor
local tempe = sensor.temperature
local url = 'http://'..smart_led_ip..'/?message='..tempe..'&static='..static
domoticz.openURL(url)
--domoticz.openURL('http://'..smart_led_ip..'static=0&local=0').afterSec(30)
-- remove the -- from line above if you want to turn off the screen after 30 seconds
- laco
It works great. Displays the temperature to 10 decimal places. This should be rounded to 1 decimal place or not. It would be good to add text about what temperature it is, exterior or interior.
Thank you very much for the great work.
VIDEO:
https://photos.app.goo.gl/c7QJSLhMCCAyLJrs9
VIDEO:
elmortero
1: easy: change "local tempe = sensor.temperature" to local tempe = domoticz.utils.round(sensor.temperature,1)laco wrote: Sunday 08 September 2019 17:19 It works great. Displays the temperature to 10 decimal places. This should be rounded to 1 decimal place or not. It would be good to add text about what temperature it is, exterior or interior.
2: even easier:
In the line
local url = 'http://'..smart_led_ip..'/?message='..tempe..'&static='..staticCode: Select all
local url = 'http://'..smart_led_ip..'/?message=Hall: '..tempe..'&static='..static- laco
Everything works but not rounding.
- laco
Sorry it works. I had it badly written.
Video:
https://photos.app.goo.gl/cNHTgj6Fy1shPoiV7
Function code dzVents:
Video:
local static = 0 -- change to 0 if you want scrolling text
local sensor = domoticz.devices('Sklenník') -- replace thermometer by the EXACT name of your sensor
local url = 'http://'..smart_led_ip..'/?message=Sklennik:'..tempe..'°C&static='..static
domoticz.openURL('http://'..smart_led_ip..'/?static=1&local=0').afterSec(10)
-- remove the -- from line above if you want to turn off the screen after 10 seconds
- laco
It might be good to send data only when the temperature changes.
- laco
I need to round the result to an integer.
I get 10.0 on the display and only need 10.
I ask for help.
I ask for help.
timer = { 'every 1 minutes'}
local smart_led_ip = '192.168.1.146' --replace by the ip address of your smart led messenger
local sensor1 = domoticz.devices('Corona nakazení SK')
local tempe1 = domoticz.utils.round(sensor1.counter)
local sensor2 = domoticz.devices('Corona nakazení vo svete')
local tempe2 = domoticz.utils.round(sensor2.counter)
local url = 'http://'..smart_led_ip..'/?message=Corona-nakazeni-SK:'..tempe1..'_ludi_Corona-SVET:'..tempe2..'_ludi&intensity=1&speed=50&static='..static
}- waaren
Can you try this ?laco wrote: Wednesday 25 March 2020 19:15 I need to round the result to an integer.
execute = function(domoticz)
local tempe1 = math.floor(sensor1.counter + 0.5)
local tempe2 = math.floor(sensor2.counter + 0.5)
}Debian buster, bullseye on RPI-4, Intel NUC.
- laco
Perfect thank you very much.
- laco
I added a reading from Custom Sensor, how do I set it up correctly?
Reporting error
2020-03-26 18:56:00.449 Error: dzVents: Error: (3.0.1) An error occurred when calling event handler Script #9 SLM CORONA
2020-03-26 18:56:00.449 Error: dzVents: Error: (3.0.1) ...ripts/dzVents/generated_scripts/Script #9 SLM CORONA.lua:15: attempt to perform arithmetic on a nil value (field 'customsensor')
local sensor3 = domoticz.devices('Dnes nakazený SK')
local tempe3 = math.floor(sensor3.customsensor + 0.5)Reporting error
- waaren
you can dolaco wrote: Thursday 26 March 2020 18:57 I added a reading from Custom Sensor, how do I set it up correctly?
local tempe3 = math.floor(tonumber(sensor3.rawData[1]) + 0.5)
