Generic Denon / Marantz python plugin
- Brutus
Re: Generic Denon / Marantz python plugin
For My conformation...
I am looking to buy the Heos by Denon DHT-S716H Soundbar and the DSW-1H Sub. These will work with the buildin HEOS by DENON plugin in Domoticz?
Mainly I wan't to change volume, Start and stop Internet Radio, Change channels when starting TV.
Thanx for any reply!
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
extremeaudio
Hi, this is a great plugin, works perfectly, thanks for this!
Only I'm not understanding the logic behind the strings used in the source label field.
The default one does not work for new receivers and has some pretty dated inputs like VCR etc. I copied what someone else is using and it works fine ->
OFF|SAT/CBL|DVD|BD|GAME|MPLAY|AUX1|AUX2|CD|TUNER|USB/IPOD
but I'm still missing out the inputs like Phono, Internet Radio, 8K. How do I add this and where in the above string?
and whats the SDK class = Receiver? Does that need to be changed for some other Denon equipment or something?
RedEarth
This is the sources string that I use with my Denon AVR2300W:extremeaudio wrote: Wednesday 10 March 2021 7:22 Hi, this is a great plugin, works perfectly, thanks for this!
Off|TV|BD|MPLAY|AUX2|SAT/CBL|GAME|CD|DVD|AUX1|TUNER|NET|BT|FAVOURITES|IRADIO|SERVER|USB/IPOD
I believe the elements in this string need to match the fixed input names that your unit supports, and then you can configure the corresponding selector values on the device that gets created on the switches tab to your own preference. Some units support source renaming but the sources string in the hardware config should not attempt to match the updated source names on the unit.
extremeaudio
On my new Marantz 5015 I cannot for the life of me figure out what to set the string for the receiver. I have this one
which ony partially works.
And I tried playing along with the selector labels and its all a jumble now and I dont know what the correct sequence is. Wish I could have buttons for 8K, Bluetooth, Phono etc.
Droombox
I have updated my PI 4 to ubuntu 21.10 and have domoticz 2021.1 running. Now the plugin won't run any more when i install it.
Can anyone help me solving this?
Might the python version 3.9.7 be the issue?
Thanks in advance
Droombox
Thanks in advance
Droombox
- Domoticz version: 2026.3
Yes, this could well be. There seems to be a major change in python 3.9 /3.10 that is blocking the python plugin framework. It is already recognized as an issue like https://github.com/domoticz/domoticz/issues/4967
manjh
- Domoticz version: 2025.2
Did you get this to work OK? I am planning to buy a DHT-S716H, and would like to link DOmoticz to it...Brutus wrote: Saturday 07 September 2019 11:21 For My conformation...
Hans
hendryman
This is an awesome plugin. Thank you for the great work!
Can it be modified so that Zone 2 is fully independent from Zone 1? E.g. choosing an Input in Zone 2 should not automatically switch on Zone 1...
It can be done with the Logitech Harmony API, and receivers like my AVR-X1700H allow for it.
rfvdboom
- Domoticz version: 2023.2
Is there something changed in the firmware of the Heos? My denon plugin isnt working anymore. I didnt update the pi or domoticz, but the plugin suddenly stoppen working. The only thing that changed is an heos update 27.09.2023
It does find my Device and loads the devices in domoticz, but there is no communication.
Errors are:
Any clue to fix this?
*Edit* I found out that i had to turn off the "Autodiscover" function in the plugin. Still dont know why this wasn't any issue before.
Errors are:
error: denon: Connectionless Transport is listening, write directive to 'Beacon' ignoredCode: Select all
Error: denon: Beacon has not responded to 10 pings, terminating connection.*Edit* I found out that i had to turn off the "Autodiscover" function in the plugin. Still dont know why this wasn't any issue before.
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
packetloss
- Domoticz version: 4.11590
Thanks for your hint.
I can confirm that with this plugin:
https://github.com/dnpwwo/Domoticz-Denon-Plugin
I am able to power on and off my Marantz Cinema 30 in the 2025.1 stable version of Domoticz. After disabling autodiscovery.
packetloss
I have an issue with several versions of Domoticz, including the latest stable. The Marantz / Denon plugin is working for switching on the Marantz amplifier, but switching off is not working. And, Domoticz is crashing
. Maybe some hints to fix?
2026-04-06T08:52:59.475458+02:00 domoticz: Activating Scene/Group: [Movie Time OFF]
2026-04-06T08:52:59.475827+02:00 domoticz: Activating Scene/Group Device: Marantz - Power (Off)
2026-04-06T08:52:59.525819+02:00 domoticz: Domoticz(pid:1477173, tid:1477195('Marantz')) received fatal signal 11 (Segmentation fault)
2026-04-06T08:52:59.525997+02:00 domoticz: siginfo address=0x168a35, address=0x727ea5c9eb2c
