Python not recognized in Domoticz 4.10726
yo3ggx
Post by yo3ggx »
I'm struggling for weeks to make the plugins work on my Domoticz installation.
I'm using CentOS 7(3.10.0-957.27.2.el7.x86_64), Domoticz 4.10726 and the following python packages installed:
python36-3.6.8-1.el7.x86_64
python36-libs-3.6.8-1.el7.x86_64
python36-devel-3.6.8-1.el7.x86_64
# python3 -V
Python 3.6.8
Tried with 3.4.x too, with the same result.
In the Domoticz Info page, I get:
About Domoticz
Version: 4.10726
Build Hash: be79a17
Compile Date: 2019-05-10 12:37:55
dzVents Version: 2.4.19
Python Version: None
What else I can try to make Python accessible from Domoticz?
Thank you.
pipiche
Re: Python not recognized in Domoticz 4.10726
Post by pipiche »
Did you try Domoticz beta ?
It looks like some users are having issues with the stable branche of Domoticz
yo3ggx
Post by yo3ggx »
No, I didn't tried. Can I revert to the stable version, if something is going wrong, without losing the configuration?
pipiche
Post by pipiche »
yo3ggx wrote: Tuesday 03 September 2019 16:15 No, I didn't tried. Can I revert to the stable version, if something is going wrong, without losing the configuration?
Most-likely the move to beta will upgrade the Domoticz Database and you won't have the possibility to downgrade.
If you do a test and you do the proper backup before and so you can restore after the test on beta, and the restore the all environment with stable
Wiki is available here.
Zigbee for Domoticz FAQ
yo3ggx
Post by yo3ggx »
I cannot compile the beta version because of some errors.
I've tried release version on a different CentOS 7 server with the same results: python installation not recognized.
I have both python 34 and 36 (including libs and devel).
What is needed for a python installation in order to be recognized by Domoticz?
Dnpwwo
Post by Dnpwwo »
Can you post the Domoticz log of Domoticz starting up? That would help.
yo3ggx
Post by yo3ggx »
As you can see, nothing about plugins.
2019-09-05 10:50:04.356 Status: Startup Path: /home/domo/domoticz/
2019-09-05 10:50:04.366 Status: WebServer(HTTP) started on address: :: with port 8282
2019-09-05 10:50:04.368 Status: WebServer(SSL) started on address: :: with port 4343
2019-09-05 10:50:04.369 Status: TCPServer: shared server started...
2019-09-05 10:50:04.369 Status: RxQueue: queue worker started...
2019-09-05 10:50:04.505 Status: Incoming connection from: 192.168.88.121
2019-09-05 10:50:06.369 Status: Hardware Monitor: Started
2019-09-05 10:50:06.570 Status: RFLink: Using serial port: /dev/ttyACM0
2019-09-05 10:50:07.491 Status: RFLink: Controller Initialized!...
2019-09-05 10:50:07.567 Status: RFLink Detected, Version: 1.1 Revision: 46 Build: 0
Xorfor
Post by Xorfor »
Did you check: Setup -> Settings -> Other.
Is on this page EventSystem (Lua/Blockly/Scripts) enabled?
yo3ggx
Post by yo3ggx »
Yes, both are enabled.
I have two Domoticz installations on two separate CentOS 7 servers and the behavior is the same. Python installation is not recognized.
Dnpwwo
Post by Dnpwwo »
@yo3ggx,
I assume from this that you built Domoticz yourself from source but Python support was not included.
I don't know much about CentOS but the CMakeLists.txt has this in it:
option(USE_PYTHON "Use Python for Plugins and Event-Scripts" YES)
IF(USE_PYTHON)
  find_package(PythonInterp 3.4)
  find_package(PythonLibs 3.4)
  IF(PYTHONLIBS_FOUND)
    MESSAGE(STATUS "Python3 includes found at: ${PYTHON_INCLUDE_PATH}")
    INCLUDE_DIRECTORIES(${PYTHON_INCLUDE_PATH})
    add_definitions(-DENABLE_PYTHON)
  ELSE(PYTHONLIBS_FOUND)
    MESSAGE(FATAL_ERROR "Python3 not found on your system, use USE_PYTHON=NO or sudo apt-get install python3-dev)")
  ENDIF(PYTHONLIBS_FOUND)
ENDIF(USE_PYTHON)
which makes the code be compiled with ENABLE_PYTHON if USE_PYTHON is specified in the 'cmake' command (which it normally is by default).
If the code is built with this flag you will always get a Python related message at startup saying which version it found or stating it didn't find one.
yo3ggx
Post by yo3ggx »
Is enabled in CMakeLists.txt.
IF(USE_PYTHON)
ENDIF(USE_PYTHON)
I have both Python 3.4 and 3.6 installed.
I've done a 'make clean' and then 'make' with the latest release.
Still the same issue and no message related to Python at startup.
[domo@nuc domoticz]# ./domoticz -www 8888 -sslwww 4443
2019-09-06 09:28:11.040  Status: Domoticz V4.10726 (c)2012-2019 GizMoCuz
2019-09-06 09:28:11.040  Status: Build Hash: be79a17, Date: 2019-05-10 12:37:55
2019-09-06 09:28:11.040  Status: Startup Path: /home/packages/domoticz/
2019-09-06 09:28:11.047  Sunrise: 05:46:00 SunSet: 18:19:00
2019-09-06 09:28:11.047  Day length: 12:33:00 Sun at south: 12:02:00
2019-09-06 09:28:11.047  Civil twilight start: 05:23:00 Civil twilight end: 18:42:00
2019-09-06 09:28:11.047  Nautical twilight start: 04:55:00 Nautical twilight end: 19:10:00
2019-09-06 09:28:11.047  Astronomical twilight start: 04:28:00 Astronomical twilight end: 19:37:00
2019-09-06 09:28:11.049  Active notification Subsystems: email (1/13)
2019-09-06 09:28:11.049  Status: WebServer(HTTP) started on address: :: with port 8888
2019-09-06 09:28:11.051  Status: WebServer(SSL) started on address: :: with port 4443
2019-09-06 09:28:11.052  Starting shared server on: :::6144
2019-09-06 09:28:11.052  Status: TCPServer: shared server started...
2019-09-06 09:28:11.052  Status: RxQueue: queue worker started...
2019-09-06 09:28:11.467  Status: Incoming connection from: 192.168.33.101
2019-09-06 09:28:13.052  Status: Hardware Monitor: Started
2019-09-06 09:28:13.253  Status: RFLink: Using serial port: /dev/ttyACM0
2019-09-06 09:28:14.174  Status: RFLink: Controller Initialized!...
2019-09-06 09:28:14.249  Status: RFLink Detected, Version: 1.1 Revision: 46 Build: 0
yo3ggx
Post by yo3ggx »
I've solved the issue based on the suggestion from here:
https://github.com/YosysHQ/nextpnr/issues/214
It was just about removing the file CMakeCache.txt and rebuilding the release version.
Now I get the following when compiling.
-- Found PythonInterp: /usr/bin/python3.4 (found suitable version "3.4.10", minimum required is "3.4")
-- Found PythonLibs: /usr/lib64/libpython3.4m.so (found suitable version "3.4.10", minimum required is "3.4")
-- Python3 includes found at: /usr/include/python3.4m
When I start domoticz, I can see in the "About" page:
Python Version: 3.6.8 (default, Apr 25 2019, 21:02:35) [GCC 4.8.5 20150623 (Red Hat 4.8.5-36)]
00luke
Target OS: OS X
Post by 00luke »
This worked for me! Just for anyone else in the future..
I just had to navigate to the domoticz install folder, run:
mv CMakeCache.txt CMakeCache.old
and then:
make
and voila - it worked! Thank you :D
