Reading XML from TME - Ethernet Thermometer Topic is solved
laco
Domoticz version: 2021.1
Post by laco »
I need to create a script for temperature and humidity from the TME sensor. https://github.com/MultiTricker/TMEP
<root xmlns="http://www.papouch.com/xml/th2e/act">
<sns id="1" type="1" status="0" unit="0" val="18.3" w-min="" w-max="" e-min-val=" -21.1" e-max-val=" 36.8" e-min-dte="03/01/2018 04:53:57" e-max-dte="07/01/2019 15:17:17"/>
<sns id="2" type="2" status="0" unit="3" val="80.8" w-min="" w-max="" e-min-val=" 15.4" e-max-val=" 100.0" e-min-dte="04/20/2019 15:26:28" e-max-dte="06/29/2018 01:13:00"/>
<sns id="3" type="3" status="0" unit="0" val="14.9" w-min="" w-max="" e-min-val=" -24.2" e-max-val=" 20.8" e-min-dte="03/01/2018 04:53:57" e-max-dte="08/01/2018 14:06:55"/>
<status frm="1" location="Jezersko 43" time="09/02/2019 15:21:07" typesens="3"/>
</root>
id1 val="18.3" is the temperature
id2 val="80.8" is the humidity
Can someone help me? well thank you
Toulon7559
Domoticz version: <2025
Re: Reading XML from TME - Ethernet Thermometer
Post by Toulon7559 »
This thread may have some applicable examples.
laco wrote: Monday 02 September 2019 15:55 I need to create a script for temperature and humidity from the TME sensor. https://www.papouch.com/en/shop/product ... ermometer/
Can you try this dzVents script ?
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
local scriptVersion = '0.201909021700'
local scriptVar  =  'thermometerIP_' .. scriptVersion
this dzVents script is used to collect data from ether thermometer Because there is no known API / JSON interface at the time this script was created, it uses a call to the Web Gui and interprets the returned XML code.
Before activating the script:
    please read the GETTING STARTED section of the dzVents wiki.
    change xxx.xxx.xxx.xxx in this script to the IP of your IP thermometer
    define a dummy hardware in domoticz if not already done
    define virtual sensor temp/humidity for this dummy hardware
and change the name in the device declarations
return
    on =
        timer = { 'every 5 minutes' },
        httpResponses = { scriptVar },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
   execute = function(dz, item)
        -- ********** local settings below this line *************
        -- change to IP of your thermometer
        local thermometerIP = 'xxx.xxx.xxx.xxx'
        -- Change devicename below to reflect your device name.
        -- You can also use idx but if you do don't use the surrounding quotes.
        local temperatureHumidity = dz.devices('xmlTempHum')
        -- ********** No changes necessary below this line *************
        -- this function will call the webpage
        local function getThermometerXML()
            local url = 'http://' .. thermometerIP .. '9050/fresh.xml'
            dz.openURL  ({ url = url, callback = scriptVar })
        local function processXML(xmlData)
            local extractedData = {}
            for word in  string.gmatch(xmlData,"(\" val=\"%d+.%d*)") do -- loop over all 'words' in the data and extract " val="##.##
                extractedData[#extractedData + 1] =  word:gsub('\" val=\"','') -- put value (after removing " val=" from the found 'word')
            return extractedData
        local function updateDevice(values)
            local function humidityStatus(temperature, humidity) -- as used in domoticz source
                humidity = tonumber(humidity)
                temperature = tonumber(temperature)
                if humidity <= 30 then return dz.HUM_DRY
                elseif humidity >= 70 then return dz.HUM_WET
                elseif  humidity >= 35 and humidity <= 65 and temperature >= 22 and temperature <= 26 then return dz.HUM_COMFORTABLE end
                return dz.HUM_NORMAL
            temperatureHumidity.updateTempHum(values[1], values[2], humidityStatus(values[1],values[2]))
       -- main
        if item.isTimer then
            getThermometerXML()
        elseif item.ok then -- statusCode == 2xx
            updateDevice(processXML(item.data))
            dz.log('Could not get (good) data from ' .. thermometerIP,dz.LOG_ERROR)
            dz.log(item.data,dz.LOG_DEBUG)
jursat
Domoticz version: 2023.2
Post by jursat »
I have configured the dzVents script according to you, but if I want to load data from the Eternet thermometer, I need to log in with the username and password in the script. Could you add that, please. thx
jursat wrote: Monday 02 September 2019 22:16 I have configured the dzVents script according to you, but if I want to load data from the Eternet thermometer, I need to log in with the username and password in the script.
This script can only do that if it is possible to include the username / password in the http call. Because I don't own the device myself I need your help on how the http call including these should look like, if at all possible with this type of script.
jursat
Post by jursat »
Thank you for your help, solved.
I wrote down my name and password in the line local url = 'http://user:password@' .. thermometerIP .. ':9050/fresh.xml'
jursat
Post by jursat »
Do you know why the graph does not show values below zero?
jursat wrote: Monday 07 October 2019 10:47 Do you know why the graph does not show values below zero?
Yes. It's because of a bug in the procesXML function :oops:
To fix; replace the function with
            for word in  string.gmatch(xmlData,"(\" val=\"%-*%+*%d+.%d*)") do -- loop over all 'words' in the data and extract " val="##.## or " val = "-##.##"
jursat
Post by jursat »
Thank you very much, I'll fix it
laco
Post by laco »
I have 2 databases on my server
MariaDB 5 port: 3306 and MariaDB 10 port: 3307
writes this setting to localhost 3306 by default
how can I change the entry to localhost 3307?
