Remote selector switch works with device but not with group
gerbenvanasselt
Domoticz version: Beta 4.1
Post by gerbenvanasselt »
I made a simple script for my aqara single button wall switch.
When I use it, Click and Double Click toggles my devices on and off.
When i do the Long Click nothing happens. And i get the error:
2019-09-01 22:55:30.983 Error: dzVents: Error: (2.4.26) An error occurred when calling event handler Dzvents SingleSw woonkamer
2019-09-01 22:55:30.983 Error: dzVents: Error: (2.4.26) ...dzVents/generated_scripts/Dzvents SingleSw woonkamer.lua:15: attempt to index local 'group' (a nil value)
       devices = {'Switch_Single'}      -- Name of your button
   execute = function(dz, item, device, group)
        if item.state == 'Click' then
            dz.devices('Plafondspot').toggleSwitch()    -- Name of your light
            dz.log(device.state, dz.LOG_INFO)
        elseif (item.state == 'Double Click') then
            dz.devices('Woonkamer_Lamp2').toggleSwitch()    -- Name of your light
        elseif  item.state == 'Long Click' then
            dz.groups('Alles_Uit').switchOff()    -- Name of your group
            dz.log(group.state, dz.LOG_INFO)
When I put the 'Long Click'part in a single script it works with the same lines.
   on = { devices = { 'Switch_Single'}        -- Name of your button
   execute = function(dz, item, group)
What am I missing here?
Re: Remote selector switch works with device but not with group
gerbenvanasselt wrote: Sunday 01 September 2019 23:11 I made a simple script for my aqara single button wall switch.
The execute function gets max. three parameters:
1. domoticz: The domoticz object. This object gives you access to almost everything in your Domoticz system, including all methods to manipulate them
2. item: Depending on what actually triggered the script, item is either a: device, variable, scene, group, timer, security or httpResponse
3. info: holds information about what triggered the script. The object has 3 attributes: Type, trigger and scriptName
These 3 parms can have different names (like dz for domoticz) but that does not change what is passed using these parms.
So your execute = function(dz, item, device, group)
gets
domoticz object in dz,
the "switch single" device in item,
info in device
and nil in group
You probably want something like:
   execute = function(dz, item)
        dz.log(item.name .. 'is' .. item.state, dz.LOG_INFO)
            dz.log('Plafondspot was ' .. dz.devices('Plafondspot').state .. ' before toggling', dz.LOG_INFO)
			dz.log('Woonkamer_Lamp2 ' .. dz.devices('Woonkamer_Lamp2').state .. ' before toggling', dz.LOG_INFO)
			dz.log('group Alles_uit has been switched Off', dz.LOG_INFO)
