smokedetectors: battery status
theo23
Post by theo23 »
Hey guys,
I have been using my Domoticz raspberry 2B with RFXCOM transceiver for a couple of years now. I mostly use it with COCO solutions.
But now I like to extend with other solutions: smoke dectectors. I have/had a couple offline cheap detectors hanging around the house, most have broken down. So I am looking into 433 Mhz capable detectors (but if other protocols are better I am also interested).
But I don't seem to find the answer to a simple question: What kind of data do the dectectors send to domoticz?
1. Alarms => the minimum minimorum, seems logical
2. Battery-level? => this is key: The main reason offline detectors don't get replaced is because batteries run down at the most inconvenient times. I would like to receive warnings or monitor their battery levels from domoticz in order to replace the batteries in time.
Does anybody know such detectors? (I can't find anything on google if for instance zwave solutions have that functionality either)
thx,
Theo
Gerwin
Re: smokedetectors: battery status
Post by Gerwin »
hello we have this ones
https://nl.aliexpress.com/item/32813697 ... b201603_52
works great, battery status,if the connection lost you get a signal,
no false report
Gerwin
theo23
Post by theo23 »
cheerz, tx
Looks a little bit like this one :) https://www.robbshop.nl/rookmelder-z-wave-plus-heiman
Anybody have any smaller suggestions?
anyways I am investigating your proposal,
tx!
Theo
akamming
Post by akamming »
i bought that one (the post from gerwin) some time ago on aliexpress just to try. I turned out it does not just look like the Heiman smoke detector, but i really is the heiman smoke detector :-)
On my system indeed it reports the alarm and the battery status, but i do not trust the battery status. I already have this device for about 9 months now and the battery status is still 100%, which cannot be true
Don't get me wrong, i am very happy with the device, so i would definitely recommend it. I just don't think the battery status is a very reliable report.
theo23
Post by theo23 »
again, thx for the additional info
on the battery issue: it should have a CR123A battery which should last 10 years. So 100% after 9 months should not be so strange...no?
