'dzVentsitize' powershell script.
thonal
Post by thonal »
I like to have all my scripts in the same language and stored in the database.
I created a powershell script that is started by a batch-file. I find it a really 'messy' way of scripting this.
So I want to convert it into 1 LUA/dzEvents script.
The powershell script looks like this:
# Hue Bridge URL
$hueBridge = "link to api"
# HUE Username
$username = 'username'
#Stop trigger
$filestop = "D:\path\scenerelax.stop"
# Time between light changes (seconds)
$waittime = 2
# Remove stop trigger
IF((Test-Path $filestop)) {
	Remove-Item -Path $filestop -Force
function LightRandom {
	param($lightID,$Sat,$maxBri,$minBri,$transTm)
		break
	# hue 65535 = 360 degree hsv
	$colorhue=(Get-Random -Minimum 37 -Maximum 50)*1000
	$brival=((Get-Random -Minimum $minBri -Maximum $maxBri)*10)-9
	if ($transTm -gt 0) {
		$strTransTm = '"transitiontime":' + $transTm
    $body = '{'+ $($strTransTm) +', "hue":'+ $($colorhue) +', "sat":' + $Sat + ', "bri":' + $brival +'}'
	$result=Invoke-RestMethod -Method PUT -Uri "$($hueBridge)/$($username)/lights/$($lightID)/state" -Body $body
	Start-Sleep -Milliseconds 100
# FUNCTION: Turn light off
function LightOff {
	param($lightID,$transTm)
		$strTransTm = ', "transitiontime":' + $transTm
    $body = '{"on":false'+ $($strTransTm) +'}'
# Main loop
while (1)
	LightRandom -lightID 8 -Sat 96 -minBri 1 -maxBri 20 -transTm 80
	Start-Sleep -s $waittime
	LightRandom -lightID 1 -Sat 228 -minBri 10 -maxBri 15 -transTm 20
	LightRandom -lightID 9 -Sat 96 -minBri 1 -maxBri 20 -transTm 80
	LightRandom -lightID 2 -Sat 228 -minBri 10 -maxBri 15 -transTm 20
	LightRandom -lightID 10 -Sat 96 -minBri 1 -maxBri 20 -transTm 80
	LightRandom -lightID 5 -Sat 96 -minBri 1 -maxBri 20 -transTm 80
	LightRandom -lightID 12 -Sat 228 -minBri 10 -maxBri 15 -transTm 20
	LightRandom -lightID 6 -Sat 96 -minBri 1 -maxBri 8 -transTm 80
	LightRandom -lightID 11 -Sat 228 -minBri 10 -maxBri 15 -transTm 20
	LightRandom -lightID 7 -Sat 96 -minBri 1 -maxBri 20 -transTm 80
# Main loop stopped
# Turn lights off
LightOff -lightID 1 -transTm 300
LightOff -lightID 2 -transTm 300
LightOff -lightID 11 -transTm 300
LightOff -lightID 12 -transTm 300
LightOff -lightID 5 -transTm 0
LightOff -lightID 6 -transTm 0
LightOff -lightID 7 -transTm 0
LightOff -lightID 8 -transTm 0
LightOff -lightID 9 -transTm 0
LightOff -lightID 10 -transTm 0
# Clear Database logs
#$sqlstring = "DELETE FROM LightingLog WHERE LightingLog.DeviceRowID in (SELECT distinct LightingLog.DeviceRowID FROM LightingLog,DeviceStatus WHERE LightingLog.DeviceRowID = DeviceStatus.ID AND DeviceStatus.Used = 1 AND DeviceStatus.Type = 241);"
#& 'D:\Domoticz\sqlite3.exe' 'D:\Domoticz\domoticz.db' $sqlstring
The script loops through a list of lights and randomize the color and intensity between set values.
Beside it uses direct access to the bridge i like to avoid, it also uses the IDs of the lights in the bridge.
Not very flexible.
A batch file starts the powershell script or it created an empty file called scenerelax.stop to stop the loop.
So I like to make a LUA/dzEvents script to get the light IDs by name, and loop them and set color and intensity.
However initial scripting already fails on the loop. I made this test script:
		scenes = {
			'Relax'
        -- FUNCTION : Sleep	Timer
        local function LoopSleep(a)
            local sec = tonumber(os.clock() + a);
            while (os.clock() < sec) do
        -- FUNCTION : Do something with light
    	local function ChangeLight(deviceIDX)
    	        domoticz.log('Device : ' .. deviceIDX)
    	        domoticz.log('Device : ' .. domoticz.devices(deviceIDX).name)
    	        --domoticz.devices(deviceIDX).dimTo(20)
    		return
    	-- Run main script
    	if (item.state == 'On') then
            while (item.state == 'On')  do
            	-- loop through configured lights in scene
                item.devices().forEach(function(device)
                    ChangeLight(device.idx)
                    os.execute('ping -n 1 -w 2000 1.2.3.4')
                end)
            domoticz.log('clearing DB ')
The loopsleep is not functioning, so as a test I used the ping methode.
All fails because I get in the log that the script ran too long.
Can anyone give me an example of a loop execution?
Thanks.
Re: 'dzVentsitize' powershell script.
thonal wrote: Thursday 29 August 2019 15:59 Can anyone give me an example of a loop execution?
The domoticz event system is not designed to deal with these kind of loops. Every script does need to end within 10 seconds, mainly because the event system is single threaded, so one script can block the complete event system if it takes too long.
So you will have to rewrite your script to deal with that.
It is also not clear to me what you try to achieve. Can you please elaborate a bit on this ?
examples of loops in Lua / dzVents
table = {a=1,b=true,c="string"}
for key, value in pairs(table) do
     print(key .. '  ' .. tostring(value) )
table={"dev_1","dev_2"}
for index, value in ipairs(table) do
     print(tostring(index) .. '  ' ..  value)
thonal
Post by thonal »
I like to create a random loop of changing colors and intensities on multiple lamps. Kind of a meditation/relaxing animated atmospheric room. However if the dzEvents is single threaded, it is basically impossible?
If you could make a predefined scene in the Hue hub that will create such a changing colors sequence, dzVents can send the required commands. The looping is then inside the hub and not in domoticz.
btw. It is not dzVents that is single threaded but the domoticz event system. So Lua, Blockly, Python or dzVents could block the eventSystem
thonal
Post by thonal »
Ok, I'm going to look into that. Thanks..
