Dashticz - Show your dashboard and how-to's!
HansieNL
Post by HansieNL »
Derik wrote: Wednesday 31 July 2019 20:22 Cannot get to work the train routes..
Like to try nijmegen centraal to limburg centraal..
Perhaps a example?
I suppose you mean to filter a destination. For limburg centraal I could not find a station/code which I could use with a provider. Tried VVS and 9292.
In the next example only the trains from Eindhoven to Schiphol Airport and Maastricht will be shown:
    //example station id: station-eindhoven
    var publictransport = {}
    publictransport.schiphol= {
    station: 'station-eindhoven',
    destination: 'Schiphol Airport,Maastricht',
    provider: '9292-train',
    show_lastupdate:false,
    icon: 'train',
    results: 7
Blah blah blah
Stepdes
Domoticz version: 2022.1
Post by Stepdes »
Mine so far, first screen almost completed.
Played with the temperature icons, icon and icon color changing depending temp. value.
Derik
Post by Derik »
Stepdes wrote: Tuesday 27 August 2019 21:48 Mine so far, first screen almost completed.
Nice
mm that screen [ rolluiken] option, please share..
And your camera option.. [ cannot get my camera to work ]
EdwinK
Post by EdwinK »
Looks nice.
Stepdes
Post by Stepdes »
Derik wrote: Tuesday 27 August 2019 21:53]
Nice
You need to count the seconds it takes to close the screens to 50% and 75% ans put this in some blocky scripts, then create a selector switch in domoticz and link this to the blocky scripts
What camera do you have? you know the url to the camera stream? if not, check Ispyconnect website fot your camera.
madradrakie
Post by madradrakie »
My water usage graph in dashticz does not show liters but m3. In domoticz the values are reported in liters (x1000). Is there a possibility to adjust the graph so it shows liters instead of m3?
madradrakie
i was also wondering if it is already possible to adjust the y-axes values in the graphs?
btw... keep up the good work, i really love dashticz and it's possibilities!!
Lokonli
Post by Lokonli »
madradrakie wrote: Wednesday 11 September 2019 21:36 My water usage graph in dashticz does not show liters but m3. In domoticz the values are reported in liters (x1000). Is there a possibility to adjust the graph so it shows liters instead of m3?
With the new graph module, a first version is available via the graphjs branch, you can create a custom graph.
See https://www.domoticz.com/forum/viewtopi ... 67&t=29145
I've posted an answer in that topic:
https://www.domoticz.com/forum/viewtopi ... 20#p223842
jgaalen
Post by jgaalen »
I'm using a samsung tab tablet as dashboard. Is there a way to open the page immediately when I double tap the screen after it's locked? Now I have to double tab the screen, swipe up to unlock, open dashtics bookmark. There's probably an easier/quicker way to open the dashboard? Thanks
jake
Post by jake »
jgaalen wrote:I'm using a samsung tab tablet as dashboard. Is there a way to open the page immediately when I double tap the screen after it's locked? Now I have to double tab the screen, swipe up to unlock, open dashtics bookmark. There's probably an easier/quicker way to open the dashboard? Thanks
Yes, with the motion detection app and dashticz loaded in chrome as a web app. Just approach the tablet and it will turn on and show dashticz. Otherwise, just move your hand in front of the camera to activate the motion.
Lokonli
Post by Lokonli »
Fully kiosk browser works pretty well
jgaalen
Post by jgaalen »
Thanks, this works really well!
krizzz
Post by krizzz »
I have a "tiny". problem and it is driving me crazy.
In my CONFIG.js I have the following block
blocks[171]['title'] = 'Chris Thuis;
blocks[171]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[171]['last_update'] = true; //if you want to show the last update specific for this block
blocks[171]['icon'] = "fa fa-male";
But the ICON displayed is soooooo tiny. I want to get this bigger. From the documentation I have read that I can adjust this in custom.css by adding:
CUSTOM CSS FILE
.fas.fa-male:before{
    font-size: 40px;
 .titlegroups[data-id='blocktitle_1'] h3 {
    font-size: 20px;
.titlegroups[data-id='blocktitle_2'] h3 {
    font-size: 20px;
.titlegroups[data-id='blocktitle_3'] h3 {
    font-size: 20px;
.titlegroups[data-id='blocktitle_4'] h3 {
    font-size: 20px;
div.mh.titlegroups {
    height: 60px !important;                /* default height=75px */
    padding-top: 3px;                       /* center text for new height */
The icon stays the same tiny size, even the adjusting the font size. Why is it not adjusting? thanks.
HansieNL
Post by HansieNL »
Can you try:
blocks[171]['icon'] = "fas fa-male";
Blah blah blah
krizzz
Post by krizzz »
HansieNL wrote: Saturday 26 October 2019 18:24 Can you try:
that's the one, your the best. In hindsight, it was so easy (voor de hand liggend).
leonhannink
Domoticz version: 4.9700
Post by leonhannink »
I installed Dashticz on my Synology and everythings works except OWM.
I put the API in Dashticz, but no forecast. Can some one help me.
CONFIG.js
(13.45 KiB) Downloaded 145 times
Lokonli
Post by Lokonli »
leonhannink wrote: Friday 01 November 2019 12:30 Hello,
config['owm_city'] looks a bit weird:
config['owm_city'] = '\'xxxxx';
but that might be copy/paste issue. There should be no slash in the name.
Can you open the developer window in chrome (press F12), and check the result of the network request to openweathermap?
(you can find it in the network tab)
leonhannink
Thanks, it works
leonhannink
other question, i have also a frame buienradar, but it's only een forcast for 1 hours, can this changed in to 12 hours??
Lokonli
Post by Lokonli »
leonhannink wrote: Friday 01 November 2019 13:57 Thanks, it works
How?
