2019-07-01 19:10:45.505 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
still no solution, but the range is 2 monthsPvhelden wrote:After 3 year stil no solution?
I have the same problem.
Anyone?
to get the right names you have to goto Hardware - Zwave - Settings, select the Node with name Unknown and press Refresh Node info (Vernieuw Node Info in Dutch) - if the Node is asleep, for instance a door sensor on battery, you have to wake up the Node.Pvhelden wrote:With the beta update V4.11230 this morning the Out of date message is gone.
But the Z-wave devices still have name Unknown.
If you update the Manufacturer_specific.xml with the version as seen on : https://github.com/OpenZWave/open-zwave ... ecific.xml the message is gone till the first update..
