I am just wondering :
if you have domoticz open in the webpage, will all sensors be loaded but just the ones from the selected tab will be shown ?
Why :
I am thinking about making a text sensor that will be populated with some html code. I want to avoid it "breaks out" the page by malformat of the HTML <Div>
if domoticz is realy selective in showing information on the tabs then i do not have to worry for breaking things by making a typo or another stupid mistake.
Question about the working of domoticz Webinterface Topic is solved
zicht
- Domoticz version: 2023.1+
- waaren
Re: Question about the working of domoticz Webinterface
Which sensors are loaded depend on the tab you requested.zicht wrote: Wednesday 21 August 2019 11:33 Hi,
Why :
If you refer to the switches tab
http://<domoticz ip>:<domoticz port>/json.htm?type=devices&filter=light&used=true&order=[Order]&plan=0Code: Select all
http://<domoticz ip>:<domoticz port>/json.htm?type=devices&filter=utility&used=true&order=[Order]&plan=0Code: Select all
http://<domoticz ip>:<domoticz port>/json.htm?type=devices&filter=weather&used=true&order=[Order]Code: Select all
http://<domoticz ip>:<domoticz port>/json.htm?type=devices&filter=temp&used=true&order=[Order]&plan=0Debian buster, bullseye on RPI-4, Intel NUC.
zicht
Thank you Waaren !
