Domoticz runs as root, and pid file for monit
AllesVanZelf
- Domoticz version: 12467
If I do "top" I can see that Domoticz runs as root. I do not like that. I want it to run as pi.
Domoticz starts from /etc/init.d/domoticz.sh as described here: wiki.
If I start it via /etc/systemd/system/domoticz.service with the User = pi variable, domoticz runs as pi. That's okay.
But, via domoticz.service it is not possible to define a pid file. like: /var/run/domoticz.pid. And this pid file I need for Monit monitoring as described in: wiki
Is it possible to start and run domoticz as pi, instead of root with the init.d method? Or is it possible to define a pid file for domoticz via /etc/systemd?
AllesVanZelf
Re: Domoticz runs as root, and pid file for monit
I just found issue: avoid running as root, actually use --chuid #3172
I tried to add: --chuid $USERNAME to the start-stop-daemon line, like:
But if I restart domotics as :
I get an pid file error. the pid file is not created then. It should have been placed in : /var/run/domoticz.pid
Can anyone help me with this?
start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
$DAEMON_ARGS \
|| return 2Code: Select all
sudo service domoticz restartCan anyone help me with this?
- waaren
I don't use systemd for domoticz myself yet and still run domoticz as root (And yes I know this not the most secure way of doing it)AllesVanZelf wrote: Monday 26 August 2019 22:31 ... I get an pid file error. the pid file is not created then. It should have been placed in : /var/run/domoticz.pid
There are quite some articles on this issue and they all point to more or less the same direction if you want your domoticz daemon executed by a non root user.
The domoticz pid file should be created in its own directory /var/run/domoticz/domoticz.pid
your daemon user (pi ?) should be given enough access to /var/run/domoticz/
Because /var/run/ is recreated on some systems at boot time these 2 actions need to be repeated before every domoticz start.
Look here for a more detailed description with an example.
Last step for you would then be to change your monit config for the domoticz alive check to look at the domoticz.pid at the new location.
AllesVanZelf
Hello Waaren,
Thank you for this answer. It is helping me a little bit further on this.
Systemd or init.d does not really mather to me, as long I am able to run domoticz as user. Pi indead.
I chose systemd now, with domoticz.sh removed from /etc/init.d/
I created: /etc/systemd/system/domoticz.service with a lot of help from internet:
Than domoticz runs as pi.
But there is no pid file made. This setting: "-pidfile /var/run/domoticz/domoticz.pid", I got from the domotics.sh script. But that does not seem to work in this ExecStart command. Am I missing something?
[Unit]
Description=domoticz_service
After=network-online.target
[Service]
User=pi
Group=users
PermissionsStartOnly=true
WorkingDirectory=/home/pi/domoticz
ExecStartPre=/usr/bin/install -d -m 0700 -o pi -g users /var/run/domoticz
ExecStartPre=setcap 'cap_net_bind_service=+ep' /home/pi/domoticz/domoticz
ExecStart=/home/pi/domoticz/domoticz -www 8090 -sslwww 8095 -pidfile /var/run/domoticz/domoticz.pid
PIDFILE=/var/run/domoticz/domoticz.pid
Restart=on-failure
RestartSec=1m
#StandardOutput=null
[Install]
WantedBy=multi-user.target But there is no pid file made. This setting: "-pidfile /var/run/domoticz/domoticz.pid", I got from the domotics.sh script. But that does not seem to work in this ExecStart command. Am I missing something?
AllesVanZelf
Yes!, I think I have it working.
I dropped systemd en tried init.d/domotics.sh again.
added: to /etc/rc.local
edited: /etc/init.d/domoticz.sh
removed the # from
added --chuid $USERNAME to the second start-stop-daemon line in /etc/init.d/domoticz.sh (around line 60):
top |grep domo
And monit as described in the wiki.
Everything seems to work well. Testing now.
mv /home/pi/domoticz/domoticz.sh /etc/init.d/domoticz.sh
rm -rf /etc/systemd/system/domoticz.service
chown root:root /etc/init.d/domoticz.sh
chmod +x /etc/init.d/domoticz.shCode: Select all
#make /var/run/domotics directory for pi
/usr/bin/install -d -m 0700 -o pi -g users /var/run/domoticz &
PIDFILE=/var/run/domoticz/$NAME.pidCode: Select all
DAEMON_ARGS="-daemon"
DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"Code: Select all
start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
|| return 1
$DAEMON_ARGS \
|| return 2
4242 pi 20 0 377068 64296 20324 S 0,3 6,8 0:46.15 domoticz
4242 pi 20 0 378092 64296 20324 S 4,9 6,8 0:46.30 domoticz
4242 pi 20 0 378092 64296 20324 S 3,6 6,8 0:46.41 domoticz Everything seems to work well. Testing now.
tybreizh29
- Target OS: -
hi
for those who wants here is the service file that creates the pid file
[Unit]
[Service]
User=pi
Group=users
ExecStartPre=/usr/bin/install -d -m 0755 -o pi -g users /var/run/domoticz
ExecStart=/home/pi/domoticz/domoticz -www 8080 -sslwww 443 -daemon -pidfile /var/run/domoticz/domoticz.pid
PIDFile=/var/run/domoticz/domoticz.pid
Restart=on-failure
RestartSec=1m
[Install]
