I installed an ID LOCK 150 with the Zwave addon to be able to do some magic from Domoticz, but so far it hasn't been very much magic.
I managed to include it as a secure node, and can lock/unlock via domoticz, and also see lock status, but that is about it
My question is if anyone has been able to do anything more with the IDLOCK?
For example I saw in some other automation software they where able to see and set PIN codes and assign it to a family member in order to send notification who opened the door etc.
/Daniel
IDLOCK 150
Re: IDLOCK 150
I also have a 150 lock, its the same for me, after i install ed the z wave module the lock started to consume battery big time, so i got tired of changing batteries all the time, so i excluded the z wave device and retutned it to the dealer.
Re: IDLOCK 150
Hi.danielxn wrote: ↑Thursday 22 August 2019 13:49 My question is if anyone has been able to do anything more with the IDLOCK?
/Daniel
I can Lock/Unlock my ID Lock 150 from Domoticz and also get notifications when it is Locked/Unlocked.
But I'm missing the ability to see who unlocked the door. I would really like to have this implemented in Domoticz.
I would also like to see if the door is open or closed.
You can set PIN codes in the "OpenZWave Control Panel" (Setup=>Hardware=>"ZWave Setup"=>Node management=>Control Panel) but not directly from Domoticz.
To mention the battery situation, I'm very pleased with it. With new firmware the battery drain issue is solved (at least for me).
