Daily backup, automatically, of database
Bernd
Domoticz version: 2023.1
Post by Bernd »
The RPi has the bad behavior to crash once in a while. All data between the period of the last manual backup and the moment of the crash is then lost. Is it possible to auto-email the database daily from out of Domoticz?
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
Re: Daily backup, automatically, of database
Bernd wrote: Saturday 17 August 2019 10:22 The RPi has the bad behavior to crash once in a while. All data between the period of the last manual backup and the moment of the crash is then lost. Is it possible to auto-email the database daily from out of Domoticz?
If your database size is not very big ( this works with my database of approximate 10 Mbyte ) you can use this in a cron job or in a bash script triggered by an domoticz event / script.
domoDir=/home/pi/domoticz    # change to location of your domoticz.db
[email protected] # change to your Email address
sudo echo "Backup attached" > message.txt
sudo cp $domoDir/domoticz.db $domoDir/backup.db
sudo mail -s "backup" $mailAddress -A $domoDir/backup.db < message.txt
sudo rm $domoDir/backup.db
sudo rm message.txt
sion
Post by sion »
Hi guys.
I’m following the guide for backing up to nas in the wiki, and have what’s probably A stupid question.
On the part of the code for deleting old backups:
# work out our cutoff date
MM=`date --date="$ndays days ago" +%b`
DD=`date --date="$ndays days ago" +%d`
TT=`date --date="$ndays days ago" +%s`
Do I just over write the MM DD and TT ?
So if I want to delete anything older than 15days, id do:
00=`date --date="$ndays days ago" +%b`
15=`date --date="$ndays days ago" +%d`
00=`date --date="$ndays days ago" +%s`
Or for files over a month:
01=`date --date="$ndays days ago" +%b`
00=`date --date="$ndays days ago" +%d`
Thanks.
Sion.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Domoticz version: 2025.1
You are referring to this wiki page I presume https://www.domoticz.com/wiki/Daily_bac ... ternal_hdd
In the extension for deleting old backups you only have to modify the ndays=19 line if you want to set something else. The rest will be done for you.
