Delay for sending alarm
teemurama
Post by teemurama »
What / where I should set .afterSec(10) when I want alarm started with 10 sec delay.
I have now code like this,
return
    on  = {
                devices = { 'Kuisti' , 'Porch movement' }
    execute = function(dz, item)
        local alarm = dz.devices('Xiaomi Gateway Alarm Ringtone')
        local gateway = dz.devices('Xiaomi RGB Gateway')
        if item.active then
            dz.notify("HÄLYTYS ULKO-OVI","Ovihälytys",dz.PRIORITY_EMERGENCY,nil,nil,dz.NSS_PUSHOVER)
hoeby
Domoticz version: V2022.1
Re: Delay for sending alarm
Post by hoeby »
Could you explane what the script needs to do?
You made 2 local, but don't use them.
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
teemurama wrote: Saturday 10 August 2019 21:37 What / where I should set .afterSec(10) when I want alarm started with 10 sec delay.
Try this
return
    on  = {
        if item.active then
            alarm.switchOn().afterSec(10)
