Pass2PHP
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
I do not mean the version of PHP but the version of pass2php.
There's no version number in the files, you have to compare against Github.
Trigun
Domoticz version: 4.10717
Re: Pass2PHP
Post by Trigun »
Egregius wrote:I do not mean the version of PHP but the version of pass2php.
Image sorry my mistake Image I’ll do a double check
Trigun
Re: Pass2PHP
Post by Trigun »
You are right! the file is different in many ways.
can I just replace the pass2php file or are there other things I need to do to get it working with the new file?
Egregius
Re: Pass2PHP
Post by Egregius »
Try and you'll see ;)
I guess you better check the SQL update script to add missing columns and the fetch domoticz file. That one stores the device type in the dt column.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:Try and you'll see ;)
Ok, this is going to sound dumb as wellImage the sql update script, is is the same as the script which creates the database?
Trigun
Re: Pass2PHP
Post by Trigun »
Trigun wrote: Wednesday 07 August 2019 16:51
I think I got it😊
Trigun
Re: Pass2PHP
Post by Trigun »
I think I got itImage
I think its not just replacing the file since more files have been updated i have to replace those too.
As for now my new _fetchdomoticz doesn’t work as it says my domoticz url is not definedImage
Trigun
Re: Pass2PHP
Post by Trigun »
after changing all the files and setting the correct rights the following errors are stil there:
if I run the _fetchdomoticz.php script I get the following error:
2019/08/08 10:53:39 [error] 638#638: *2339 FastCGI sent in stderr: "PHP message: PHP Notice:  Undefined variable: domoticzurl in /var/www/html/secure/_fetchdomoticz.php on line 14
PHP message: PHP Warning:  file_get_contents(/json.htm?type=devices&used=true): failed to open stream: No such file or directory in /var/www/html/secure/_fetchdomoticz.php on line 14" while reading response header from upstream, client: 192.168.1.40, server: _, request: "GET /secure/_fetchdomoticz.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "192.168.1.200"
since I am only using a cron60 and a cron3600 (from the previous setup) it also get the following error.
2019/08/08 10:54:01 [error] 638#638: *2363 FastCGI sent in stderr: "PHP message: PHP Notice:  Undefined index: PIR_Badkamer in /var/www/html/secure/_cron60.php on line 20" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /secure/cron.php?cron10&verwarming&rolluiken&cron60&cron120&cron180 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "127.0.0.1"
both errors did not appear with my previous setup. any idea to solve these?
I made an extensive guide for setting up pass2php but I don't remember putting in my domoticz url somewhere as it has always been 'Localhost'
do you have any idea how to solve these?
Egregius
Re: Pass2PHP
Post by Egregius »
$domoticzurl has to be set in your config.php file.
There's an example in the secure folder.
I store mine in /var/www so it doesn't get pushed to Github.
Egregius
Re: Pass2PHP
Post by Egregius »
The second error about PIR_Badkamer means that you're using a name in the cron file that doesn't exists in the database.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:$domoticzurl has to be set in your config.php file.
I know but it’s already in there: 127.0.0.1:8080
This should be correct.
I believe the reason for the second error is due the _fetch file not working.
Using my old _fetch file gives the same error.
I think I have to start over to het iT working again
Trigun
Re: Pass2PHP
Post by Trigun »
ok, GOT IT SOLVED!!!
I thought I had this issue before and after scrolling down this topic I found it!
The folowing lines need to be added to the _Fetchdomoticz.php file.
require '/var/www/config.php';
require 'functions.php';
Is there a chance you want to add them to your file as well? ( for future updates ;) )
I also added this to my pass2php guide. if anyone is interested I attached it :)
please let me know if anyone thinks I missed something.
8-8-2019 Pass2php Guide.txt
(4.23 KiB) Downloaded 167 times
of course all the credits go Egregius(the majority of the credits :)) and Sincze for helping me out and spending time for all my noob questions!
again, thanks guys!
cheers!
Egregius
Re: Pass2PHP
Post by Egregius »
My fetchdomoticz is included in my floorplan so I don’t need it ;)
It might be a hard way to learn but this way you also learn how things hang together.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Thursday 08 August 2019 22:14 My fetchdomoticz is included in my floorplan so I don’t need it ;)
you are absolutely right and thats ok :)
as long as I can ask a few questions so once in a while :)
so once I got everything working again I updated again to you latest files.
I have a very basic setup compared to yours but my cron files used to work with it.
my cron 60 looks like:
<?php
lg('this is __cron60 --> a 1 minute Cron');
if ($d['Garageportaal']['s']=='On'&&$d['PIR_Garageportaal']['s']=='Off'&&past('Garageportaal')>60) {
	sw('Garageportaal', 'Off');
if ($d['Garageportaal']['s']=='On'&&$d['PIR_Garage']['s']=='Off'&&past('Garageportaal')>60) {
if ($d['Berging']['s']=='On'&&$d['PIR_Berging']['s']=='Off'&&past('Berging')>60) {
	sw('Berging', 'Off');
if ($d['Overloop']['s']=='On'&&$d['Auto']['s']=='Off'&&$d['PIR_Overloop']['s']=='Off'&&past('Overloop')>60) {
	sw('Overloop', 'Off');
lg('STATUS ==> Badkamer='.$d['Badkamer']['s'].', past='.past('Badkamer'));
if ($d['Badkamer']['s']>=1&&$d['Auto']['s']=='Off'&&past('Badkamer')>60){
	sw('Badkamer', 'Off');
lg('STATUS ==> BANO_Outdoor-Rain='.$d['BANO_Outdoor-Rain']['s'].', Buienradar_Solar-Radiation='.$d['Buienradar_Solar-Radiation']['s'].', Tuinsproeiers='.$d['Tuinsproeiers']['s']);
if (TIME>=strtotime('T04:00')&&TIME<=strtotime('T07:00')&&$d['BANO_Outdoor-Rain']['s']<1&&$d['Buienradar_Solar-Radiation']['s']<250&&$d['Tuinsproeiers']['s']=='Off') {
	sw('Tuinsproeiers', 'On');
with this setup I am unfortunately getting this error which I cant figure out.
2019/08/08 22:24:02 [error] 703#703: *21135 FastCGI sent in stderr: "PHP message: PHP Notice:  Undefined variable: d in /var/www/html/secure/_cron60.php on line 6
PHP message: PHP Notice:  Undefined variable: d in /var/www/html/secure/_cron60.php on line 10
PHP message: PHP Notice:  Undefined variable: d in /var/www/html/secure/_cron60.php on line 14
PHP message: PHP Notice:  Undefined variable: d in /var/www/html/secure/_cron60.php on line 18
PHP message: PHP Notice:  Undefined variable: d in /var/www/html/secure/_cron60.php on line 22" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /secure/cron.php?cron60 HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "127.0.0.1"
you have any idea where this comes from?
If I compare the cron60 to yours the difference is too big to see what I need to change :(
Egregius
Re: Pass2PHP
Post by Egregius »
You need line 15 of cron.php:
$d=fetchdata();
$d is now filled with the fetchdata() function. So you can include the functions file without it calling the data everytime.
And you can add multiple $d=fetchdata() lines if you need an updated dataset.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:You need line 15 of cron.php:
$d=fetchdata();
Ok, so just add $d=fetchdata(); to the cron60 file?
Sorry, but how to put it and where?
Egregius
Re: Pass2PHP
Post by Egregius »
Trigun
Re: Pass2PHP
Post by Trigun »
OK, NICE!!! the error is gone!
now I need to get my cron working again.
are there any lines I need to add to the cron file?
Egregius
Re: Pass2PHP
Post by Egregius »
You mean in cron60?
Normally not.
$d is fetched in cron.php before including cron60 so $d is available.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Friday 09 August 2019 10:03 You mean in cron60?
Normally not.
Tge strange thing is that my cron files are actually working now!
the only thing is that I have have multiple LG line in my cron60 file see:
<?php
if ($d['Badkamer']['s']>=50&&$d['Auto']['s']=='Off'&&past('Badkamer')>60){
but I cannot see them comming back in the Log file once I am doing a tail -f of the domoticz.log file
